As inspired by pg5200's Buggy and Tamiya's Fighting Buggy, I've built this RC Buggy MOC. It's simple, fast and stable.
Features:
- Total no. of pieces is less than 400
- Around 1/15 to 1/16 scale
- Requires a BuWizz 1.0/2.0 or CaDA or Mould King remote battery hub (SBrick should be possible by placing the hub on top of the battery box)
- PF Servo Motor for the steering
- RC Buggy Motor or BuWizz Motor for the rear driving
- Gear ratio is 1.4 : 1
- Transverse damper rear suspension similar to Fighting Buggy
- Rear camber angle is about +1 degree
- Optional 4 LED lights (instruction not included)
Instruction available at https://rebrickable.com/mocs/MOC-76795/
Have fun and enjoy!
It's not in Minifig scale, just give you an idea of its size.
It has a +1 degree of rear camber angle.
Edited by A_C
Added test run video
That's a really good looking buggy, at least it's properly hiding the motors inside the body, but I think you should make a video showing how it works - the gearing matters, so it may be either really slow or won't be able to climb at all etc.
From what i can see it could/should be a 1,4:1 gearing. Could reach 2,5 to 4km/h. Not sure about the torque.
Am I missing something, or does "1° camber" actually mean "I didn't make a strong rear axle"?
56mm tyres * pi for circumference * 1240rpm on a buggy motor at 9v * 20/28 reduction on the differential * 60 minutes in an hour / 1,000,000 mm in a km
=9.3km/h
With so few parts I'm betting it'll rip.
It's feature, not a bug!
=9.3km/h
I'm tempted to disagree. Looks like the slower output is used, thus 780rpm @9V (According to Philos homepage). That's nearly 6km/h... in theory. But i might be wrong.
@Andman you've come from 2.5-4 to nearly 6, but you're still wrong - one of us read Philo's page wrong (it was you).
I'd like to know how you get 1° of camber in Lego on purpose, unless it means 1° of slack either direction from square.
Edited by amorti
12 minutes ago, amorti said:
@Andman one of us read Philo's page wrong (it was you).
You are referring to the non-loaded characteristics, which is described here:
I was referring to the loaded characteristics.
5292
Torque
Rotation
speed
Current
Mechanical
power
Electrical
power
Efficiency
4.5 V
5.7 N.cm
150 rpm
1.36 A
0.87 W
6.12 W
14 %
6 V
5.7 N.cm
380 rpm
1.38 A
2.27 W
8.28 W
27 %
7.5 V
5.7 N.cm
580 rpm
1.37 A
3.45 W
10.3 W
34 %
9 V
5.7 N.cm
 780 rpm
1.40 A
4.61 W
12.6 W
37 %
10.5 V
5.7 N.cm
1030 rpm
1.46A
6.16 W
15.3 W
40 %
I'm again tempted to say that the values from table of loaded characteristics are closer to the real life conditions for this moc than the non-loaded characteristics of that motor.
Your turn :-)
Edited by Andman
4 minutes ago, amorti said:
Well, it runs on buwizz, so that's 11.2v which would give somewhere over 1030rpm.
I'll accept a mutual loss :pir-huzzah1:
:-D I didn't read that it is powered by a buwizz. That's a game changer. There is only one solution! @A_C, please make a video and show how fast it can go!
Thanks all for your feedback.
First of all, I don't have a BuWizz, and I'm using a compatible Buggy motor only. When the remote battery is fully charged, it has about 8.1V
And I've just uploaded a test run video but I cannot provide the actual speed in readings. But I think it's pretty fast, and it's definitely not a climber or crawler.
Just added another yellow version at here. It's not only another color version, but also replaced the expensive light reflector parts.
