Hi,
Is there some way to put the glass inside of the grooves of the modified 1x2 tiles?
x5 of the glass panes is equal to 33L (or 16 tiles with a 1L gap as shown below)
Ive heard of people editing the Parameters inside of the LXF file to finely move parts but I have no idea how to do this
so help would be greatly appreciated!, The bottom and top frames should hopefully be the right space apart for the glass to fit between.
Here's a Picture:
And Here is the LXF file to save aligning the windows up (this will crash LDD constantly so DONT try this unless youre editing the file using the text editor perhaps)
Thanks, S
I gave it a try, but the grill piece is badly rendered in LDD as the collisions dont take into acount the actuall grill pieces so it behaves as a 1x2 tile.
Ok thanks anyway.
ill just buy some blue glass panels.
The gap between the two window frame bits is fine in life
I'm not using trans black - not enough on Bricklink. ill need around 80 for 1 train (yes 20 per carriage, 4 carriages maybe 8 will be taken away off of the train.
Edited by SNIPE
