Idea is very good. Months ago I was thinking that (based on license) we could expect / hope for Liebherr mining truck to fit R9800 based on 94.3 (Unimog tires) with same motorized functions as 42030 B model (just use new PU from 42099 set) and new big linear actuators from R9800
This would be the wheelbase and trackwidth when i use the T284 Dimensions.
Iam not sure if i use setup because the outer tires wouldnt take any load and i want load on any wheel.
Just now, efferman said:
following the pictures you are right. looks more or less like this in offset.
Yup, and you have 6 holes, so you can use the 3 remainig to fill them with pins and pulley wheels. Also dont forget to put and axle 8 with stop inside the defender's rim to hold it all together even better.
One thing, the cross shaped axle holder is aligned with pinholes, so it should be offset by half a stud in the right. Otherwise the wheel would not fit the planetary hub.
The Pinhole connector and axlehole section has the same dimension like every unimog rim. so it would fit.
Small update:
Edited by efferman
A small break for Lunch. I hope i wasnt to much into the tilting angle and the mechanics can lift a full Dump body
seems to work
Edited by efferman
