LDD Extended: Color Palette's lowest color row is going behind the taskbar.
Probably a known thing, but still need to be reminded of imho.
What is your screen resolution?
Not really... Can you share it?
No need. Its just an empty area, with the model is not visible, nor that baseplate thingy that is defaultly there. But the camera controls are there.
This actualyl did happen to me, I had some sinatll problems and ever since if I open LDD i get a blank. I just drag a file in LDD and it opens it (cant be bothered to reinstall)
It could be a camera problem. I've had occasions where I've perfectly aligned the camera to take an overhead shot, saved the file, and re-opened it to discover what you have described. If you can upload the LXF here, I or somebody else can paste some new camera co-ordinates into the file so that you can see the model again.
Camera saves position only if you save with a change. Just opening lxf changing position and saving wont save camera position, you have to change something.
I don't know if this has been reported, but the invisibility tool has changed so that separate parts of minifig torsos and legs are not recognized. It used to be possible to make only part of them invisible, now it makes the whole part invisible. I used this once to create an edge detail out of minifig legs, but that capability is now gone.
The technic clutch ring that goes over an axle joiner allows for some parts to slide in which would never fit in real live
Eg: a half bush
The boundaries on 11302 are way out of whack. It's hard to describe, so see this image. As you can see, not even a Technic axle will occupy the module directly beside middle of the part, despite an obvious gap between 11302 and the axle. This seriously limits the usefulness of 11302 on LDD, since the flat edge it one of its primary features.
Edited by Lyichir
Well spotted!
Found another one, which shouldn't need an image (my screenshot tool hasn't worked properly in a while, making it harder to get good screenshots of errors). Standard 3.2mm clips SHOULD be able to clip to the back end of 50859 Motorcycle Frame 6M, but there's no connection point there. This connection is occasionally used to secure motorbikes when they're parked or loaded onto vehicles.
Edited by Lyichir
After receiving both updates almost everything is working fine.
I checked my previous error reports/investigations:
:thumbup:
- shock absorber 76537 is finally available again :sweet:
- space guns 86208 and 3959 are OK now, they can fit to the motorcycle frame 50859 (link)
- rim 6582 geometry is OK now (link)
:thumbdown:
- toggel joint 32126 still does not allow stud connection (link)
- panels 87080 and 87086 still do not allow stud connection (link)
We don't seem to have a bug thread yet, so, I'll just tell you here that the Lightsaber Handles (64567 and 23306) no longer fit in 1x1 Plates w/ Upright Holders (2555, 12825. and 15712).
Also, when I tried to re-open LDD to verify these numbers, I got the "Internet Connection Failed" message and had to run it in offline mode.
EDIT: Sorry, I should have figured this was for new bugs, too. Anyway, it opens fine now? I dunno.
Edited by Superkalle
struck some text to avoid confusion
Using brickset 1564.1, found two errors.
With shock absorber part 76537, the two halves can be rotated independently, but move together, and also the overall length cannot be adjusted from within LDD, have not checked if editing the LXFML file works on this part yet.
Also, "train motor 2006", 54754, does not connect correctly to IR receiver connection cord, but does connect correctly to a 2x2 plate
Edited by JGW3000
Oh, nooo :angry: I hope we don't have to wait another 6 month to fix the fix. I'm wondering how this part was tested before the release... :tongue:
Workaround for rotating the shock absorber:
Edited by mzoli
Fellow Builders,
Are you guys running on the new update? I've removed the software three times, hoping that the new 'fix' has been loaded when I attempt to download the software again. :blush:
I've been waiting for this 'fix' to materialize sometime very soon, I've plenty of building to do, but can't get this software to keep from crashing every time I try to open. :angry::thumbdown:
Are there any links to the 'fixed' software, or do I need to be patient and try some other day? :sceptic:
