Hello,
@michaelgale
There are 4 Contacts on each side of the Speed-Controller.
For Power-Supply I expect only 2. Why are there 4 ? For what are the 2 additional used ?
What happens when you connect 2 Speed-controllers antiparallel side-by-side ? Shortage ?
When you have to use more USB-C injections for Power-Supply, how is secured Power-Balancing beteen them ?
Is there Isolation-Tape between the two Supply-Groups necessary ?
Or can this Supply to other Modules be switched OFF (ev. by configuration via USB ?) ?
What are the technical Data of the Speed-Controller ?
Where to find them ?
What Power does the Spee-Controller support ?
I assume you did much test with various Motors, so how moch motors can be driven (at what conditions on mechanical Load to be moved) ?
And what is then the impact on Rail-Lenght between multi-point supply ?
Can 2 or more Speed-Controllers work together for Multiple-Point-Supply (all outputs driven by a single Target-Value) ?
Does the Speed-Controller support DCC ?
Jo
Edited by BrickTronic
Typo
While I can't speak to the more technical questions, I can address a few of the simpler questions until Michael gets a chance to step in and field the advanced ones...
Where to find them: The initial batch has already sold out on fxbricks.com, but they might be available from next month at JB Spielwaren.
Power level: 9V, with speed controlled via PWM on an infinitely variable slider (as opposed to fixed voltage steps like a first-party speed regulator). No 12V support on this design; that may come in the future with a 'pro' version of the speed controller. There are two selectable PWM modes (can hold down the function button to change between them).
Motor handling: From personal experience, I can tell you the controller handles four 9V motors at once quite comfortably.
Impact on rail length between power drops: Given that both are 9V systems, this is comparable to what you'd experience with a first-party speed regulator. I use two equally spaced power drops for a layout with around 45 feet of track and that's more than adequate.
2 or more speed controllers together: Michael specifically advised me against doing this; it is preferable to use one controller per loop and stack multiple power drops on its output, rather than attempting to use two controllers.
DCC support: Not in this model; that would be a consideration for future deluxe versions.
Edited by Narissis
2 hours ago, Narissis said:
Shipment arrived today; I took some quick & dirty photos of the insert for you:
https://imgur.com/a/DVsZupy
Hello,
Thanks !
Looks very interesting.
Can't wait to get more Info.
Especially how USB-C Power Balancing is working and why there are the 4 "Magnetic"-Contacts used.
Jo
