Service Notice / Slow Site speed due a DDoS attack ×
I can easily use hub motors using virtual joypads, however nothing happens when I replace the joypad blocks with remote control blocks. How do I go about it? I want the motors to run as long as a button is held, just like it works with the joypads.
Edited by MTBRICKS
What kind of hub and program do you use?
Lego Move Hub, the big one with 2 motors and the official PoweredUp app.
I see.
Here is a very simple approach:
The two motor blocks on the right set speed to 50 (upper) resp 0 (lower).
The "remote-icon"-block most left equals 1, what means the "+" button.
And the block below points to HUB2 (which is the remote) / Button-Set  B.
So you have to connect the hub as 01 and the remote as 02
Duplicate all and change the remote port  and motor port for second motor.
Edited by Lok24
Looks like rocket science to me, but I will give it a go for sure. Thanks a lot.
:sweet:
I thought you were familiar with the Power App and use it already.
But feel free to ask, if something doesn't work as expected..
35 minutes ago, Lok24 said:
:sweet:
Im familiar with the app in the way that people give me instructions and I copy them lmao. The app is so user unfriendly I cant get anything done. Literally zero explanation of anything in there, just pictures that dont tell me anything. I had to find block descriptions online just to know what the hell the blocks even do. It feels so much better using grown-up programming software that actually tells you what it does :D.
Anyway, back to the point, so far the code you provided only powers the motor when I press the play button and nothing reacts to any remote input whatsoever. Also, theoretically speaking, will this ensure
a smooth motor control or are we just doing a +50 -50 kind of thing?
Edited by MTBRICKS
3 minutes ago, vascolp said:
Haver a look at  Pybricks
Documented, able to python code programming or block programming...
Yeah I heard about it, it allows some new features too, like connecting the PS4 controller and stuff. I remember there being something I had to do first to make it work and I didnt want to bother with that yet. I will definitely give it a try in the future tho.
I find it very user friendly, it is designed to be used by children, experimenting with it. As with a age of 6 years they could't read any explanations.
There was the Boost Set (17101) with over 60 "lessons" to learn it.
The explanation is done by the colors/topics of the blocks, and the symbols.
Yes, I thought that was the requirement
Yes, of course, but with a different program.
Sorry that my example wasn't helpful.
Edited by Lok24
I have thought about this several times and I cant imagine how a child could do anything worthwile with this user interface. You would literally have to use all the blocks in all the variations which could take hundreds of hours just to see what they do. A lot of wasted time for no reason. I hate just thinking about it. Lets move on.
Ah so I wasnt stupid after all. Or at least not that stupid. As a sidenote, why did you include the remote control block in the code when it does nothing and only the play button does things? Is it supposed to work or not?
No, you can easily reduce the number of shown icons für beginners. Look at the "settings".
The children I played with on many exhibitions were between say 4 to 8 years , and all of then could move "Vernie" from the boost set within few (less then three) minutes (Boost-app, which has slightly different blocks)
 it detects the button pressed an delivers the value to the "compare" block, and if it equals "1" then motor start. There are other values, you can see then when selecting the right "value" field"
You can see this easily, if have you use program with only the one(!) remote control block and press a button.
I think yes, here when I press the B+ button  the motor runs.
When remote is connected as HUB 02.
Edited by Lok24
This is some high level sorcery. Ima check it out later and see what went wrong in there. Its always the little things that screw up the entire thing.
So I did a thorough examination and there really was a mistake in my code. That infinite loop thingy was added to the end of the sequence rather than combined with the middle part of the code and also for some reason I had to change hub 1 to hub 2, even though I connected the hub first and only then connected the remote. In any case, its working now, so many thanks my dude.
You first connect the Move Hub to the app. This is Hub 01.
Then you connect the remote to the app. This is Hub 02.
That should be shown in the list of connections.
And this the reason why have to set the value to "2" in the Hub-Selection-block (bottom left, the Icon with the two hubs)
BTW: why don't you connect the remote directly  to the Hub, without any app?
But I did connect the hub first and remote second, it doesnt even work any other way. Thats why I was surprised setting it to hub 2 worked when its actually hub 1. I really have no idea why. And how do you connect the remote to the hub without the app? Im pretty sure I tried it when I got it but since I have given up, there must have been something not working for me.
EDIT: Ive just tried connecting the remote to the hub without the app, it doesnt work at all. And when I use the app to connect the hub and then try to connect the remote without the app, it doesnt work either. So for me the app is the only way it seems.
Edited by MTBRICKS
Press green button on the Move Hub, the press green button on the remote. No smartdevice required.
But thats what Im doing. Every time I do this both things start flashing white light and then the light stops completely.
