because solid Axles and suspensions are the biggest problem for beginners i have started on my german homeforum a collection thread for vehicle axles and suspensions, and i think here should exist a thread like this too. feel free to post your own axles and suspensions. please with picture and if possible with an LDD file that it can simple reproduced.
here a first bunch of my axles
heavyplanet trackwidth is variable
planet with difflock
planet with difflock and power drivethrough
driven and steered independent suspension with 11 studs between towballs, unfortunately no ldd file possible
flat and solid axle
please post your own axles too
Edited by efferman
Okay, here are mine:
First the small ones:
This one is and improved axle used in my mini 41999.
Its made for light trucks only:
http://www.brickshel...s/miniaxle1.lxf
Second there is an axle I actually came up with yesterday in my mini unimog. It features a differential and actual portal gears, making it the smallest lego portal axle:
http://www.brickshel...s/miniaxle2.lxf
Third axle is made for the small truck wheels and the slightly larger baloon wheels:
http://www.brickshel...s/miniaxle3.lxf
One of the older, yet still good axles is the one used in raptor:
http://www.brickshel.../raptoraxle.lxf
Next are the axles used in cheetah. They are very robust and efficient:
http://www.brickshel...cheetahaxle.lxf
Slowly getting to the big boys... Here's a slightly updated axle used in the monster. Its extremely robust and can carry high torque.
http://www.brickshel...monsteraxle.lxf
And the latest mother of (half)axles is the one used in the fox. Its the most efficient of the bunch thanks to only two gears used.
http://www.brickshel...les/foxaxle.lxf
Edited by Zblj
Here is a small front axle for a live setup, including drive and steering.
Here is a dynamic rear differential independent setup.
Here is a portal axle with turntables setup that includes a limited slip differential.
Finally, here is a portal axle independent set-up with MacPherson suspension.
I had a lot of trouble finding plenty of steer and suspension articulation which I think is important, because you can turn in small spaces and there is less of a limit for when the spring bottoms out, and the ride height be can adjusted more this way. until I build the first example I posted. it does have some problems such as bump steer, You just have to stick with it and try and most of the time it will be possible in lego.
Edited by SNIPE
@ Dans lego
Sheepo made one: http://www.sheepo.es...-live-axle.html
If i mention right a 3-link setup with a simple panhard bar, something like the Ford Mustang has. Nicjasno made one aswell, but is a little bit big. :tongue:
I would also like to see some live axles setups like the Ford Mustang has for ideas.
Another example: https://www.dropbox....Opel Suspension
Edited by jesse66058
Here's what I developed for chitty. I will be refining for the GTHO very soon.
I made a more reliable version but didnt take any pics, and choose this one because of looks.
  On 2/7/2014 at 6:18 PM, Zblj said:
Here's a miniature tatra suspesnion:
Zblj, I'm sorry so much, but steering don't want to work :( but rear part is excellent
Steering works, all right, check here:
How did you manage to make such animation/rotation in LDD?
On my version of LDD, I can only animate small/simple mechanisms ...
I might as well post my dual live rear axle(s) with central diff for "8258-sized-trucks"
Using the A-arms like this minimizes sideways swaying :thumbup:
LDD file available here
question; not only for you Michael, but for all of you respected builders - do you know how to make steered driver independent suspension axle that has differential but is more narrow than 18 studs? It must use differential at the center of axle and universal joints?
Maybe something like this, but without portal axles and place a differential in the chassis. I know that you wouldn't get the same performance with a different differential setup, but it's all I've got at the moment.
This thread is heaven.
Thank you to everyone for their posts and another thank you for uploading any LDD files too, it helps WAY more :)!
Small detail perhaps but nonetheless. With the new differentials and symmetric constructions (drive-shaft in the middle), widths can be only odd numbers, I.e., 17 or 19 ... But not 18.
If you start by sandwiching a 3L differential between two thin liftarms, you can build an even-width suspension module.
But thats really prone to slipping and its very messy and weak.
That's what I thought, too, until Saberwing40k posted this design, which I've built and found quite strong (other than some flex in the wishbones):
