Hi all,
today I want to show some pictures of my trolley-bus.
It has PF-Receiver,battery-box and a PF-Motor.
Steering is establishd via the trolley system.
Two Videos
Steering mechanism
Two different types of masts, one made of rails, the other of rigid hoses
Test-tracks, mixed with both types (as I got only 4 hoses)
The automatic switch point
The technique inside
Some Pictures
Hope you like this little project
cu
Lok24
Edited by Lok24
Incredible! The design of any individual piece alone (bus body, pf/steering systems, or masts) would be impressive but together its just great - hope a lot of train folks come over to this forum to see this as well!
..... hope a lot of train folks come over to this forum to see this as well!
... you could add a link there .... :wink:
As it is no train I posted it here.
Vice versa you find some other similar constructions in the train section :laugh:
cu
Lok24
Edited by Lok24
This is absolutely great work!
And it's also nice to see that the bus design is not compromised- it looks very real.
Is it going to the Wien westbahnhof, by any chance?...
Nice compact steering mechanism. Are there any issues with the gears slipping?
Thanks.
No, there is no slipping at all, because there is a tile round 2x2 with hole (dark grey) under the central gear, which keeps it in the upper position, so the both gears on the side can't move downwards.
As you see in the video there isn't much room between the bus and the baseplates, but it takes absolutely the same way every time with great precision.
cu
Lok24
Edited by Lok24
That's some brilliant engineering right there - very clever solution. And the bus looks the part, too. Well done!
The construction looks so simple but yet this is the most amazing part of it. It looks like something everyone could built, but only a few or maybe no one could think of it. Absolutely amazing. :thumbup:
What a great idea to use the overhead cables to steer the bus. But why not use tubes on the straight stretches? That would make it still better.
Greetings from Arnhem, Trolleybus city of the Netherlands.
I agree that would make it cleaner the plates just look to thick to me.
If you read the original post again, you'll see this:
Awsome Job !
Simple but not simplistic. In a word, Ingenious !
Look forward to seeing you integrate it in a city !
Edited by G0M
