Showing results for tags 'wing body'.
Hello Eurobrickers! This is my the biggest project. In this year, we celebrate 130 years of Coca-Cola, when the druggist J.S. Pemberton invented the recipe for this popular soft drink, so I decided to build a Coca-Cola truck with a wing body semi-trailer. Also truck was an inspiration to build my MOC. I know, that is not Xmas time and if you do not like a music, which I used in my video, you can choose one of them: , or this .Some technical informations: Truck: Dimensions: length: 52 cm, width: 22 cm, height: 22 cm, weight: over 2.3 kg, Power Functions: drive – PF XL motor, steering – PF servo motor, up/down 3rd rear axle – M motor, locked/opening fifth wheel – M motor, 1 x PF battery box, 2 x PF IR receiver, 2 x PF IR remote control, 4 x PF lights, 1 x PF extension wire 20 cm. The truck has drive, steering, up/down 3rd rear axle and a fifth wheel is locked/opened. The truck has also opening doors, opening door in second cabin, a hood can be lifted up to access the engine, which is eight piston engine connected with a rear axle. The second cabin has a removable roof to access a battery box. The stairs you can use as a toolbox or you can put a fire extinguisher Semi-trailer: Dimensions: length: 70 cm, width: 19 cm, height: 25 cm, weight: over 3.1 kg Power Functions: opening wing doors – PF M motor with gear box, lift in/out – PF M motor, lift up/down – M motor, outriggers – M motor, 1 x PF battery box, 2 x PF IR receiver, 2 x PF IR remote control, 1 x PF lights, 2 x PF extension wire 20 cm. The whole set is 106 cm long. I think, that is wrong weight both of them, and truck and trailer are heavier The semi-trailer has opening side and rear doors and also opening doors to a locker and an extension ramp. I hope you like it. Full BS gallery Some pictures:
- 27 replies
