Showing results for tags 'western star'.
In the last couple of months I have, amongst other projects, been working on the rerelease of Truck T12. Because the detachable gooseneck lowboy "Trailer Tr4 MkII" can be combined with my previously released trucks and with Technic set 8258 it is why I released it first. Instructions for this lowboy have been asked so many times that I thought it would make sense to start with it. Normally I start with a truck followed by a trailer to join it. Model "Truck T12 MkII" and is build after the Mack Granite with LEGO® in scale 1:17,5 and motorized using LEGO® Power Functions. It is a model of a Mack Granite 6x4 day cab truck. Both the looks and specifications are adjusted to match lowboy ”Trailer Tr4 MkII” and the optional jeep and booster ”Trailer Tr4 MkII Add1”. This rather heavy lowboy trailer combination, which might include a load, requires some extra power.Even though this truck is designed to go with ”Trailer Tr4 MkII” plus ”Trailer Tr4 MkII Add1” lowboy combination in the first place, it doesn’t necessarily mean it can't be used with other available trailers as well. If you prefer to give it a flat bed or log trailer, you are free to do so! If a different trailer is used it might be useful to give this truck's drivetrain a various gear setup. For this a separate PDF file is available that tells you what gear reductions to use with which trailer. It also shows you how to do so. Evidently the torque will be reduced, but with lighter weight trailers that is no problem at all. This Mack Granite model is powered by a Mack MP8 engine which is visible with the hood opened. This power source is an inline 6 cylinder engine with a displacement of 13.0 L. The horsepower range is from 425 up to 505 HP and this engine has a torque range from 1570 to 1760. You could build it yourself, building instructions and inventory/parts list are available. You will be very excited from the moment you start the build of "Truck T12 MkII" till you finish it with about 360 different parts totaling 1900 pieces.
- 36 replies
- solid axle
- servo
(and 8 more)
Tagged with:
