Showing results for tags 'tv tower'.
TV tower built in capital of Lithuania - Vilnius, is the tallest structure in country measuring 326.5 m (1,071 ft). The construction of the tower started on 31 May 1974 and finished on December 30, 1980. The observation deck 165 m (541 ft) from the ground houses the cafe "Paukščių takas" (English: Milky Way), offers a picturesque view of the city and its surroundings, and sports a rotating platform that revolves once every 45 minutes. High-speed elevators reach the cafe from ground level in 40 seconds. On clear days, visibility can extend as far as Elektrėnai, a city approximately 40 km (25 mi) west. Text source - Wikipedia This is my first MOC in Architecture-like style, so it took me a while to figure out the right brick combinations for better looks. Round tile 8 x 8 and same sized dish determined the scale of entire creation. I'm surprised how stable the final model is - the core is build is several larger parts which are held by simple clutch force - MOC can be handled without risk of immediate collapse. There are two parts of the MOC I'm particularly proud of. First one is the structure in the middle - the one, that makes tapered cone. Three layers of SNOT bricks extend the outer ring by half a plate (1 module) from each side. And it is surprisingly rigid! Next one is the bottom part, which makes a round building at the base. More squarish shape was expected to be created, but it ended up in almost perfect circle. Picture explains it all: MOC stats: Height 565mm Scale ~ 1:580
