Showing results for tags 'small v4'.
Had some inspiration to build another little pneumatic model after thinking of my little wheel loader that I build a couple of years ago. They aren't the same scale, because I was going for a look where the small pumps look "big" on the bulldozer. So this is smaller. Functions: - Blade up/down with pneumatics - Plow up/down with pneumatics - Mini V4 engine with differential A little video: Some more pics: I wanted to use that panel for the front blade, because I think it suits it. Decided to add a little grey line to fit with the sides and break up an otherwise very yellow blade In this photo of the side you can also see the blue "chair" (2L pin joiner) that I use to contol the pump below the "chair". The blue hose above the engine is from the pump. I tried to hide the switches at the rear as much as I could, while still being easy to access. Next photo a little more up close: Used Lego's colour coding for the pneumatic hoses. Plow ready for some lifting action. Or to actually plow... You probably wonder why on earth did I want a diff in there? Well I wondered that myself as well actually a couple of time during the build, but the real life versions got it, so why not this It sure provided a fun challenge to route all those hoses around it. It's very snug, but nothing touches the gears or the engine. Thanks for watching.
