Showing results for tags 'shock absorber'.
Hello Guys, Today I would like to present my first moc here, which was built for the Buwizz fast car competition. I have been back to Lego for about 2 years now. I have built a few Mocs, and mods, but I have not found them good enough to show to others. :) I hope you like this little buggy, let me give you some more information about the build. I was half way with a build when I heard about the competition, so I decided to change that according to the rules. I usually build with more motors, so the challenge for me was to make the model efficient. I started with a 4wd version, with differential on both axles. The main feature was the independent suspension with small pneumatic pistons as shock absorbers. I started to test this solution on Agrofs buggy modded by Kbalage. It worked well, so I decided to use this solution in this build to help the stability of the car after the jump. As you see, I had to give up the 4wd setup, as the single rc buggy motor even with Buwizz 2.0 was just not enough to do the job. I have some pictures of the old version, and I have a plan to put 2 motors in it, will post that, once its built. So I decided to reduce the friction by eliminating all the gearing, so the rear wheels are propelled from fast output. I hope you will like it Guys, let me know what you think. :) An earlier version with 4WD: At the very beginning: Suspension test: Here is the final video: A few photos:
- 16 replies
- buwizz
- rc buggy motor
(and 1 more)
Tagged with:
I recently bought 8 Damped Shock Absorbers to use for suspension, but I was wondering what else they could be used for? What have you used them for? And what is the most unusual use you can think of? For anyone in Australia, here is where I got them: Lego Technic Lego Pneumatic Shock Absorbers, and the seller has heaps of them!
- 22 replies
