Showing results for tags 'semi-trailer'.
Hello Eurobrickers! This is my the biggest project. In this year, we celebrate 130 years of Coca-Cola, when the druggist J.S. Pemberton invented the recipe for this popular soft drink, so I decided to build a Coca-Cola truck with a wing body semi-trailer. Also truck was an inspiration to build my MOC. I know, that is not Xmas time and if you do not like a music, which I used in my video, you can choose one of them: , or this .Some technical informations: Truck: Dimensions: length: 52 cm, width: 22 cm, height: 22 cm, weight: over 2.3 kg, Power Functions: drive – PF XL motor, steering – PF servo motor, up/down 3rd rear axle – M motor, locked/opening fifth wheel – M motor, 1 x PF battery box, 2 x PF IR receiver, 2 x PF IR remote control, 4 x PF lights, 1 x PF extension wire 20 cm. The truck has drive, steering, up/down 3rd rear axle and a fifth wheel is locked/opened. The truck has also opening doors, opening door in second cabin, a hood can be lifted up to access the engine, which is eight piston engine connected with a rear axle. The second cabin has a removable roof to access a battery box. The stairs you can use as a toolbox or you can put a fire extinguisher Semi-trailer: Dimensions: length: 70 cm, width: 19 cm, height: 25 cm, weight: over 3.1 kg Power Functions: opening wing doors – PF M motor with gear box, lift in/out – PF M motor, lift up/down – M motor, outriggers – M motor, 1 x PF battery box, 2 x PF IR receiver, 2 x PF IR remote control, 1 x PF lights, 2 x PF extension wire 20 cm. The whole set is 106 cm long. I think, that is wrong weight both of them, and truck and trailer are heavier The semi-trailer has opening side and rear doors and also opening doors to a locker and an extension ramp. I hope you like it. Full BS gallery Some pictures:
- 27 replies
Inspired by Holgi's MOC my friend rr76 and I built a 1:17 scale trailer (Arocs) for overseas containers. There are mountings for one 40', two 20' containers or one 20' bulk container in the middle of the trailer. Furthermore, the left box is free as a tool box. The rebrickable version is controlled with a Buwizz, because the Powered Up cables are too short, this is not feasible in the conventional way. RC functions: - Raising and lowering the supports - Raising and lowering the lift axle - parking brake - rear light My red one is a conversion to a battery box and Sbrick, i only need a housing in DBG. The grey prototype was build with PU, becaus the cables are to short and the PU-M motor is to expensive i used PU-PF adapters. The lights are custom LED with the Lego PU LED cable. Currently there is a 40' container and the prototype of a bulk container, we're still working on a 20' container. The instruction are available at rebrickable for free: https://rebrickable.com/users/Huwi/mocs/
- 5 replies
- container
- semi-trailer
(and 2 more)
Tagged with:
