Showing results for tags 'rz-1'.
I LOVED building Jerac's A-wing so much that decided to give a go at the Resistance RZ-2 A-Wing. I chose dark blue, because a few crucial pieces were not made in the regular blue color, and I still feel it works. I tried to be as accurate as possible, while sticking to mini-fig scale, without using stickers. No real play features, as I was going for accuracy, but it's durable and swooshable. I'm really pleased with how the "humps" on the hood, and the red lines, or "call-sign" on the wing turned out. As you can see in the pictures you can change the number of red lines to your liking - and they fit snuggly and wont fall out. Let me know what you think! RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr RZ-2 A-WING by M G, on Flickr
Hello everybody! I am a fan of many Star Wars spaceship designs, and while most of them I consider to be "among my favourite", the classic movie A-Wing permanently occupies the top of the list. This caused me to build this little ship many times in my life, basically since I was able to assemble two bricks together. This build I am showing today is currently the end of the line for plenty of iterations, most importantly the one from 2008 some people here know: I still like how it looks, even after all these years, but this build had plenty of issues. First, it was fragile: even on the photo you can see it has stickers wrapped around its wedge. They were needed, as the interior consisted of a mess of flex tubing, minifig arms and similar pieces arranged in a way to hold the cones in exactly proper angle. Which, actually, did not work, so I taped the sides to make "missile launchers". The ship also uses some rare pieces, for example the 30x20 wheels coming from one single set released in 1978 or something, there are no landing gear, I didn't like the front wedge notch being in different angle, and on top of that, I messed up with proportions in some areas. 10 years later, working with BrickVault on instructions, topic of renewing the A-Wing was sure to return, and it did. I hoped it would be a simple renewal of an old concept, but it ended up being totally redone inside, so it still looks like 2008 one, but this time it can be safely picked up. It also has proper missile launchers, even if a bit too far back compared to the original, and foldable landing gear I am really happy with, as it folds seamlessly. Most of the issues with proportions and overall "cleanliness" were also fixed. Surely this is not an ultimate A-Wing but I worked pretty hard to make it as close as possible to such one. Having the movie ship done was not the end of the story, though, as BrickVault guys really wanted the Rebels' show ships, too. Originally they were supposed to be recolors and not much more, but it looked wrong. Rebels' designs are notorious for making odd alterations to classic designs, and a recolor of base RZ-1 just did not look good enough. So there we go, I though, let's make these few little adjustments to make the Rebels' ship. Few little adjustments are: - move the engines a plate or two toward the bottom, because they are not centered horizontally like they are in RZ-1 - remove the notch in front wedge and add that few details required in various colour variants - make the engines shorter and add the little notches they have around in front and back, while still having similar dimater to the original RZ-1 engines - make different "center thruster" housing - make rear body shorter - make stabilizers smaller overall and wrap up behind engines - change the fuselage assembly behind the cockpit - update the cannon design ...it ended up being half of the ship redone, eh, but I believe it was worth it! The ships are done in several variants: Instructions for this design are available at brickvault.toys, and a little summary and showcase of some features is available here: Thanks for watching and tell me what you think!
First up, I want to give a shout out to Jerac, Krispy and Renegade Clone for their fantastic MOC designs... especially Renegade Clone, whose A-Wing design this is based on. My goal with adapting Renegade Clones design was to provide a base platform that all the colour variants could readily be produced using only bricks, whilst achieving the proportions and angles of the SW Rebels source material. In reviewing these renders, one change I'll likely make is to replace the 4 1x1 round tiles (98138) on the aft thruster assembly with transparent bright-orange to match the main engines. When looking at source material, there were some variations not only in the colours for the main ship, but in the style of the wing mounted weapons, so I decided to get a little creative with those. Feedback and constructive criticisms welcomed.
Hi. Here's some photos of my work in progress at the moment, the RZ-1 A-wing. This is drawing deeply from the models of Jerac and others. I'll add more to this post shortly. flickr album link: https://www.flickr.c...157659454465594 First stage Optimised stabiliser design, completed greebles on the rear, cannon added, experimenting with solutions for the front taper, other minor changes Let me know what you think below or on the flickr comments ! (:
