Showing results for tags 'planetary hubs'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Inspired by the release of the planetary hubs and the diff lock idea from Zetors I decided to create a proper, realistic Tatra 8x8 with the following goals: Use of planetary hubs - Keeping it realistic, so no portal ones No load bearing axles - Most other models used the same drive axle to also hold the half-axles in place which increased friction in the driveline Realistic steering setup - Using a smillar mechanism the real trucks use Differential locks on all wheels - Each axle has it's own diff lock + a central one Here's what I came up with so far... The concept uses the blue bevel gears to transfer the power to the half-axles without spinning the pivot axle. This also allows for wheels to turn at different speeds when cornering. Once the power is transfered to the half-axles an additional gearing is used before the power is delivered to the wheel. Total gearing on half-axles alone is 1:9. Differential locks work by locking one of the differential's output to the main drive axle. As mentioned before all 4 axles have lockable differentials along with the central differential. Steering uses a couple of 9L links turned by the turntable acruated by an 8 tooth gear. This setup provides the front axles with slightly different steering angles. The model will probably powered with 4 of the BuWizz motors. Total gear ratio is 1:21 which should give the model around 900-1000 Ncm torque. I think the concept looks very promising so far and I will keep on building it virtually until I'm confident enough to order parts.
