Showing results for tags 'light sensor'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. I'm taking the knowledge I learned from a class last semester and applying it to my long-term layout. The devices pictured here form the basis of a block-occupancy detector system that will be placed within my long-term layout to facilitate some autonomous functions, such as signals, automatic level crossings, and remote switching. To start with, let's have a quick look at the FPGA development board I'm using for the controller. This is the Basys 3 Artix-7 FPGA Trainer board, sold by Digilent. The Artix-7 FPGA chip used here has 33,280 logic cells divided into 5200 slices (each slice containing four 6-input LUTs and eight flip-flops). It runs off of a 5V power supply, delivered either through USB or an external power jack. There are four 2x6 'PMOD' connectors (standard spacing, thankfully), one of which also acts as an analog input. There is also a VGA connector and a full-size USB as well. In addition, there are 16 switches and five pushbuttons available, as well as 16 LEDs that can be accessed by the user. It uses the Xilinx Vivado Design Suite for programming. Next, we have the sensor I'm currently using. ...Or at the very least, something very similar to it. It's one of those fairly generic designs that's copied by everybody and sold for very little, so it doesn't really matter which one you get so long as it looks the same. This, however, is not the final sensor I'll be using - this design is extremely directional, in that it's only sensitive enough for my application when the light source is in front of the module. It turns out that the version which has a photoresistor as its light-sensitive element is much better at detecting the ambient light level, and is actually somewhat cheaper. These type of sensors will run happily on anything from 3.3-5V, and have two outputs: an analog output, which will vary its voltage from 0V up to the voltage of the supply, and a digital output, which operates in the reverse of what you'd typically expect - that is, it outputs a high signal (high being the voltage of the supply) when the light level is below the trigger point set by the potentiometer, and outputs a low signal whenever the light level is above the trigger point. There is one power LED and an LED that reflects the opposite state of the digital output. In my first picture, I have attached the VCC pin of the sensor to one of the VCC connections on the Basys 3 - pins 6 and 12 on the PMOD connectors act as 3.3V supplies, with pins 5 and 11 acting as a ground, and pins 1-4 and 7-10 acting as signal lines - and the GND pin on the sensor to one of the ground connections on the Basys 3. The digital output (DO) on the sensor is connected to one of the signal lines on that same PMOD connector, and the analog output (AO) is left unattached (if I connect AO to a ground connection, the sensor acts as if a bright light is in front of it no matter what). Next, we have to write the code that defines the behavior of the controller! FPGAs are interesting because rather than a microcontroller executing commands, the code written actually tells the FPGA to re-wire itself internally to produce hardware-only logic that provides the desired behavior (this is where the name Field-Programmable Gate Array comes from). As such, the code isn't written in C or Java, but in Verilog and other Hardware-Descriptive Languages (HDLs). The code files can be treated as individual 'blocks' of logic, and can easily be combined together to produce much more complex behaviors than we see here. This is the only Verilog module that runs the system currently: module bodsensortest(led,bodsensor); output led; // Goes to some LED on the Basys 3 input bodsensor; // Comes from AO on the sensor board assign led=!bodsensor; // Oddly enough the AO output is an inverse output - it goes LOW when the light level is above the trigger point endmodule Here I'm defining a module called 'bodsensortest', with the output 'led' and the input 'bodsensor'. Then I tell the Basys 3 to set the output 'led' to the opposite state of 'bodsensor'. In addition to building the actual logic, it's advised to write a testbench module that hooks up to your first module and allows you to simulate it before sending the code off to the board: `timescale 1ns/100ps module tb_bodsensortest; reg tbodsensor; wire tled; bodsensortest dut(tled,tbodsensor); initial begin $dumpfile("tb_bodsensortest.vcd"); $dumpvars(0,tb_bodsensortest); tbodsensor=0; #40 // Default should be sensor 'uncovered' tbodsensor=1; #40 // Sensor now 'covered' #20 $finish; // total sim time: 100ns end endmodule Here I define the units of time that I'm simulating in, the module, and inputs (reg) and outputs (wire) for the testbench file. Then I tell the system to create a .vcd (timing diagram) file, and in that file examine ALL variables within the testbench file. Then I toggle the state of tbodsensor off and on to simulate something passing over the sensor, with some delays. Finally, I add in a 20ns delay to round it to a nice number. Lastly, in order to actually make this work on the board, I have to play with a constraints file that tells the board what I/O pins to look at and what variables they correspond to: ## This file is a general .xdc for the Basys3 rev B board ## To use it in a project: ## - uncomment the lines corresponding to used pins ## - rename the used ports (in each line, after get_ports) according to the top level signal names in the project ## LEDs set_property PACKAGE_PIN U16 [get_ports {led}] set_property IOSTANDARD LVCMOS33 [get_ports {led}] ##Pmod Header JA ##Sch name = JA10 set_property PACKAGE_PIN G3 [get_ports {bodsensor}] set_property IOSTANDARD LVCMOS33 [get_ports {bodsensor}] Here I'm telling the Basys 3 that one of the LEDs on the board is the output from the first module, and the input for that module comes from one of the PMOD connections. After this, I plug these files into the Vivado software, and generate a file that's sent to the board. Because FPGAs are volatile, I also told the software to generate a configuration file that's saved in flash memory on the Basys 3 so it can automatically re-configure itself every time I turn it back on, rather than having to reprogram it with a USB. Otherwise, I would only be able to run this program until the Basys 3 was turned off! All of this makes a little LED on the board turn on and off Also, I've actually got the function backwards - I want the module to follow the backwards behavior of the sensor, as I want there to be a signal whenever a train is passing over the sensor (it makes more logical sense to me that way). However, so far I'm quite pleased with what I've accomplished as we didn't really do much with outside inputs during the class - we stuck mainly to the switches and buttons provided!
  2. So basically I am doing the sumobot challenge where you have to build a robot that has a max length and width of 20 cm each. The arena of the competition is a hexagon with white borders and has 6 poles. The rules and everything is online and is pretty self-explanatory and we are also allowed to have 1 extra sensor than what is in a standard nxt set which is 1 of every sensor in case you were wondering (so we could have 2 light sensors instead of 1). I was wondering how we would detect the poles and and avoid them without interfering with the actual pushing off other people (so not as simple as a touch sensor in the front since other bots would push that too. Someone told me there is multiple ways to do it. I don't really know any efficient ones. Any ideas? Sorry if I posted in the wrong area I am new.
