Showing results for tags 'free wheel'.
I'm trying to design a realistically functioning model of a diesel locomotive. I don't care about looks at this point, given how limited my collection is, but what I'm wanting to aim for is a locomotive that appears to operate realistically. The chassis is going to be 6 studs wide for now as a prototype, and 46 studs long. In order of the drivetrain, it's going to be M-motor -> one way clutch -> flywheel -> forward/reverse gearbox -> trucks. This should allow the locomotive to realistically creep forward, move, and slow down gradually as if it were an actual diesel locomotive with a fluid drive transmission, or like HarmanMotor's fluid drive bus. The only problem I'm encountering so far is a compact, low friction one way clutch design. I've tried the one design made with the 3 rubber 2 stud lifters, but that doesn't work. It's too large and I can't get it to function properly without a large flywheel which wouldn't fit in the body, or base of the locomotive. I'm trying to design something compact enough you could put it inside the base or body of any diesel or electric loco, and dramatically improve the functionality. Any help?
- 7 replies
- train
- locomotive
(and 4 more)
Tagged with:
