Showing results for tags 'fire dept'.
CBFD Hazmat 1 is the primary hazardous materials team in the city! It is supported by Hazmat 4, which acts as the secondary/decon team, and the 2 Squad companies. This rig is the replacement for the 2019 Seagrave/SVI after it was involved in a traffic collision. Castle Beach Fire Department is proud to present brand new Hazardous Materials 1. Built on a 2020 Seagrave Marauder II cab with SVI bodywork, this rig replaces the 2019 Seagrave/SVI Hazmat rig, after the rig was involved in a traffic accident. Unlike most special operations apparatus, the new HM1 does not have a slide out. However, a command center is located in the cab along with a Flow Sciences biological safety cabinet to analyze foreign samples. HM1 also carries a wide variety of meters and detection kits to fulfill the motto “In omnia paratus,” which means “ready for anything.” HM1 is staffed daily by 8 firefighters, all of whom are hazardous materials specialists. Technical specs: 2020 Seagrave Marauder II/SVI Hazmat 500-hp Cummins X-12 engine Federal Signal Lighting Hi-Viz BG2 scene lighting B&M Super Chief mechanical Siren Federal Signal Touchmaster Siren Grover Air horns NightScan PowerLite Radios and command equipment Detection cameras (heat sensitive, infrared) Wilburt Telescoping Pneumatic Mast Pelco Command Camera System Climatronics Tecmet II weather station Battery operated Holmatro extraction tools Vanair Pro Air Compressor Harrison On-Board generator Flow Sciences interior lab containment enclosure Gas Chromatography/Mass Spectrometer Extensive library of MSDS handbooks CO monitors Level A and B entry suits EOD suits Testing equipment and meters 60 minute air bottles Leak and spill kits for chlorine and other dangerous chemicals Sparkless power-tools Propane burn off kits Pipe sealing equipment Mercury leak kit Decontamination equipment Oil Absorbents Emulsifiers Immersion suits Credit: David H for the compartments Inspired by: LAFD Squad 21 Denver HAMER 1 Seattle Hazmat 1 FDNY Hazmat 1 Numerous upgrades to the cab include the Hi-Viz BG2 scene lights on the brow. Additional warning systems like the B&M Super Chief mechanical siren, Federal Signal Touchmaster, and the Grover air horns aid in clearing streets. Hazmat 1 is the first special ops rig in many years to not have a slide-out. As the crew rides in either the walk-in portion of the apparatus or in HM1A, the area behind the driver and officer is setup for command purposes. In addition, the Flow Sciences biological safety cabinet was moved to this location as well. The apparatus committee worked closely with SVI to optimize storage of the equipment that HM1 carries. The rear of the apparatus shows the thermal camera, the steps leading to the roof of the rig, and the door to the walk-in portion. The apparatus is a full walk-through and provides ample space for the crew to suit up at scenes. Hence, all the various suits, from the Level A suits to the regular PPE are stored here to provide rapid access to suits. As Castle Beach has a large port, railways, a large international airport, and several industrial areas, there are many high risk sections of the city, necessitating the need for a highly trained hazmat team. Hazmat 1 is also certified to respond to chemical, biological, radiological, nuclear, and explosives calls, fulfilling the catchphrase of the company, “In Omnia Paramus.” \ Hazmat 1 carries many non-sparking tools to allow for rescues in areas where there may be gases that could potentially ignite should a spark occur. Hazmat 1 responds to any situation needing their expertise, whether it is a fuel leak, mercury spill, or any other response that poses a threat to the health of our minifigures.
