Showing results for tags 'droid gunship'.
Wow, first real post here! This is my modification of TLG's 75042 Droid Gunship, in an attempt to make it more film-accurate. List of Modifications: - removed play features such as dropping bombs and spring launchers - slimmed down light laser cannons on winglets - changed main laser cannon to add articulation and increase accuracy - added additional pieces to front to cover gaps between ball turrets and nose - added more accurate payload on underside of disc - removed cockpit hinge, filled details appropriately Here's a view of the whole thing. Off to the side, you can see the original cockpit section, which can be easily installed As a little bonus, you can open it to reveal the HMP's Droid Brain! In canon, nearly all of the Confederacy's space and ground "vehicles" were actually independently-controlled droids. However, many games portray them as vehicles with onboard pilots, so you can easily remove the droid brain, as it is only attached via the front two studs. Above is a close-up of the droid brain. The image below shows the improved payload of missiles. Let me know what you think! I'm planning to make more accurate versions of other ships as well, so let me know what you'd like to see next!
