Showing results for tags 'construction equipment'.
Caterpillar 990
jorgeopesi posted a topic in LEGO Technic, Mindstorms, Model Team and Scale Modeling
Like I said in this topic Z-bar linkage help, I am building another wheel loader. This time is the Caterpillar 990 which is the biggest one I can build because the bigger ones like the 992, 993 or 994 have two cylinders for the bucket and it would be impossible keep the width in scale. It uses the Class tyres and in the beginning it had to be manual but I have so many room that I am thinking on a complete pneumatic RC loader. I hope you like the WIP process every advice is wellcome. I am trying wheels, should I have to buy the yellow ones?.- 59 replies
- wheel loader
- construction equipment
(and 2 more)
Tagged with:
I am finally done with my first real MOC that I am happy with and proud to show to all of you LEGO fans out there. This is my version of the Volvo L120H wheel loader. It is build in scale 1:17. I have used a M-motor for the sterring and bucket tipping, a L-motor for the bucket-arm lifting and a XL-motor for the drive. All of them are geared down to ensure enough power (except the sterring). I am using two standard IR receivers and the small rechargeable battery pack. I have considered lights but I think the wires will look messy. I am considering building it in Stud.io to get a brick count and if I do that then instruction might be an option. I have made it from these specs (page 18): https://www.volvoce.com/-/media/volvoce/global/products/wheel-loaders/wheel-loaders/brochures/brochure_l110h_l120h_stagev_en_21_20057313_b.pdf?v=QA5EPw Worker on Studio gallery: https://www.bricklink.com/v3/studio/design.page?idModel=82000 Worker instructions: http://liex.dk/LEGO_MOCs/Worker_1-17/Worker - scale 1-17.pdf And now for the pictures, I hope you enjoy.
- 27 replies
- 1:17
(and 2 more)
Tagged with:
This is a realistic version of the Bobcat S130. This LEGO TECHNIC model built for 1:14 in scale. Functions: moving piston working lift arm tipping bucket Dimensions: long: 230mm wide: 115mm high: 150mm (with bucket lowered) Bricks of the set: about 670 piece Look at the other pictures and If you like this model please support on the LEGO IDEAS side. Link: LEGO IDEAS/Bobcat S130 Thank you for watching and any support!
