Showing results for tags 'constitution train chase'.
[full gallery] I have modified the locomotive from the Lone Ranger, Constitution Train Chase (Lego set 79111) to add working driver rods. I had to completely rework the pilot to make everything work, but I think the final design is pretty good. The new model is the same width as the original, one stud longer, and it has working rods. The mechanicals are packed in very efficiently. The front wheel just barely clears the cow catcher, the side rods just barely clear the crossheads, I came up with a clever bearing to fit over the moving pilot axle, etc.. With the moving rods I think this engine is shaping up to be pretty sharp. A larger tender would be nice, and one of these days I'll take a stab at that. The one tradeoff (and I'm not sure it is much of a tradeoff) is the fact that I had to convert it from a Ten Wheeler to a Mogul. Here's a shot of the modified engine on a curve I've prepared instructions for the modification and have already uploaded jpegs to brickshelf (I'm working on finding a good home for the .pdf version). There are two versions of the instructions: V1 is for building the modified model from scratch, V2 is for retrofitting the completed model after it has been built. To build this modified model you will need the parts that come with Lego set 79111 and the additional parts listed on the last two pages of the instructions. Note that this build requires 4 non-Lego pieces for the driver rods, available here. [full gallery]
- 15 replies
- steam
- custom parts
(and 4 more)
Tagged with:
79111 Constitution Train Chase review Latest pictures and information: (click for higher resolution pictures) Thanks to Grogall for the links. Expected price: £79.99/€99.99/$99.99 original post ----------------------------------------------------------------------------------------------------------------------------------- We have seen that there is a new brickset item: ... Although it is just speculation, I think it must be a train like the famous "The General" from the civil war. Read further: http://trains.nute.w... Train Race.htm
- 118 replies
- pictures in first post
- price
- (and 3 more)
