Showing results for tags 'cathegory 1'.
For my contest entry, I wanted to make a small, yet feature packed little ship. Made in LDD and rendered in Bricklink Studio, It was based on 7416 Adventurer's set Emperor's ship, but I've remade it to be less of a Chinese Junk, and more of a Golden Age of Piracy Gunboat. I've added a bowsprit, cannon, steering wheel and a Poopdeck, and replaced cloth Junk sail with brick built Jib and Gaff Rigged sails (Ideally I'd use cloth sails, but I don't know how to do that in Studio). I'm very proud how it turned out, and I'm sure it would be a fine addition to Admiral Woodhouse's Navy. It's a very versatile vessel, perfect for patroling the shore, escorting and interception, and it's manned by a crew of three: Two Marines and One Captain. This is how it looks like from Starboard and Port. Even though the cabin under the poopdeck doesn't have much space, it's enough to keep charts and delicate navigation instruments away from the Elements. There's also a nice little hold for confiscated pirate contraband and treasure, though, to gain access to it, you have to remove the cannon. I guess that's what the huge crane at the Eldorado Fortress is for. Obviously it's the first cathegory entry, and I mainly tried to emulate the 2009 era, as it's evident by the Minifig Prints, and rather modern parts. EDIT: After hearing your suggestions, Here's the improved model: The Sails are now tan and with much less visible studs. New cannon! it's still not perfect, but it's much smaller, and has a built in stud shooter. And yes, you can open the hold with cannon still attached: Other changes: -Added Figurehead -Reduced number of golden decorations. Now it should be more aesthetically coherent. -Tweaked the stern a little bit. Added colours flag, and an additional lantern. - Made the hold trapdoor open the other way, this should make it more accessible.
- 36 replies
