Showing results for tags 'buggy motrs'.
I had an idea of making a small baja-truck for some while and with the Artic vehicle contest it was a perfect match. Here is the concept, made in a Studio file. So, the ”functions” are those of a normal RC car - detachable body, steering and forward/ reverse. For this, the model has 1x servo-motor and 2x buggy motors; with 1x battery hub, it should weight around 800 g or about 28.21 oz. I still didnt found a secure way to attach the battery hubs in the back but I am already thinking of making frames only for BuWizz 2.0 and the MouldKing 4.0 hub, because BuWizz 3.0 has a greater chance of hitting the motors and takes more space too. Also, the suspension travel is pretty big in the front and in the back too, although I have reduced the travel for the front arms because of the over-steer. Here is the almost finished front of the original variant of the model, which had a big over-steer issue. I had to modify the motor frame too. The first 2 images are the concept version and the 3rd image is the last variant, with longer liftarms that allow the suspension to work (you can see the swapped 5L liftarms and the soft springs, which were too soft, obviously). I dont like the current body-work, so the amin thing on the ”to do list” for the Ice baja is to modify the body-work as much as it is possible. Anyway.............in 2 days I kind of managed to finish the chassis. As I only have one buggy motor ”functional” (is partially burned too), I cant test it properly, but I will see what I can do; until then, I am pretty pleased with result of the chassis. More photos will follow with the progress of the new body-work at least, but if I find something to improve on the chassis, then it will be with the chassis too. (The tires in the last 2 photos will be replaced with official Lego ones in the next photos; also, those tires are messy, so sorry for all of that :/ )
- 11 replies
- buggy motrs
- baja
(and 1 more)
Tagged with:
