Showing results for tags 'bridge layer'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. Dear LEGO fans!I present to you my LEGO MOC, my all time favourite armored vehicle, the M60A1 AVLB - Armored vehicle-launched bridge. When I first saw this video of the real machine, I was mind-blown. Being a mostly Technic builder, I instantly wanted to try building it fully functional. There are some fantastic Technic models already out there. But most suffer from abstract looks of the bridge in particular, due to obvious weight problems. Well, unfortunately I learned about it the hard way, as the plate & tile clad bridge was just too heavy for the launcher to be able to lift it, even when the bridge was stripped of all the cladding. (Here is the link to some photos of my fallen Technic Mastodon, if someone is interested). To heal my wounds after Technic debacle, I decided to try it out in minifig scale, trying to make it as accurate as possible with at least manual functionality of the real machine. The result is in front of you. I must admit, I am very satisfied with the result, and this is why the model is still sitting on my shelf in my LEGO room for almost two years now (I usually disassemble all my creations very quickly). So after almost two years I finally managed to edit photos and also make instructions and a short video. So, about the actual MOC... I must admit that I was at first heavily inspired by this fantastic M60A1 Brickmania's Cody Osell. This video and a couple of their photos was the only brick built reference material, so the only similar thing might be the looks of the underside and it was helpful to determine the size of the tank and the bridge afterwards. According to dimensions of the real one I found on-line, it is built in approximately 1:33 scale and is a completely manual model, although the cores of both the tank and the scissor bridge are made of Technic bricks. It has some moderate play-ability, like independent torsion suspension of all road wheels, but it is more meant to be - and I absolutely love it that way - a display piece. Since I decided to go for more or less authentic looks and not so much for the actual functions, the bridge is actually heavier than the launcher, so I hope it is clear, that the tank cannot hold the bridge in raised position by itself. I used two pillars made of trans-clear panels below the hinges of the bridge to support it. The loose end of the bridge on the other hand is only supported with a string - "steel cord/cable" on the hinge. There is some photo editing done on the raised bridge photos to look like it is elevated solely by the tank. I hope you don't feel too fooled by that. I'm sure that those readers and fans, that know much more about the M60A1 AVLB, than I do, will find many details not accurate, but overall, I think that the main presence is there. Enough writing. I'll let the photos speak. The V12 engine is only indicated with visible 6 pistons, the other 6 (nonexistent in the model) are "deeper" under the hull :-) Here an example of IRL display, where translear pillar is visible to aid keeping in the position on those slippery tiles. Also, when bridge is carried on the tank, i used a special brick-built pedestal to aid the rather soft independent torsion suspension of all road wheels. It was my wish to see it on some diorama, alongside a ruined bridge or something... who knows, maybe someday... Some data of the model are in order as well I guess... The final part count came down to 2233 parts (1100 for the bridge 1133 for the tank) in 266 different lots + 2x 30 cm of non LEGO stiff and strong (non elastic) string + some short thin string to attach some of the clutter on the tank. Launcher dimensions (LxWxH): 20,5 (24,5) x 11,5 x 11 cm or 26 (31) x 14,5 x 14 studs with the launching arm put over the hull. Launcher weight: 546 grams Bridge dimensions (LxWxH): 57 x 14 x 3,6 cm or 71 x 17,5 x 4,5 studs when extended. Bridge weight: 738 grams. Here are some comparisons with the sketches I found on-line. As you can see on the second one, the height on the tank is close, but I wasn't able to keep the bridge thin enough to perfectly match the scale. I guess the road wheels could be a bit bigger too, but it is LEGO after all and with smaller scales compromises are inevitable. I also prepared a short video presentation with some nice animations from stud.io, although I admit photos do this model more justice: With this creation, I decided for the first time to seriously venture in creating a digital model, some renders and building instructions by using Stud.io designer. It took some time and ended up consisting of 420 pages and 627 steps in total. I didn't get into modelling of the strings with other CAD software (I found this is the only thing to improve in Stud.io at the moment), so I enhanced the instructions with some photo and text guides as well. This said - the string for "steel cable" for the hinge is the only non lego part of the build. The instructions can be found and purchased (yes trying to get on the money train , not that I'm too optimistic) here on rebrickable.com. Below I add a couple of renders used to "enrich" the building instructions and some pages of the actual instructions as well. Thank you for taking time to read this through and thank you in advance for your constructive criticism and support. I hope someone decides to build it as well. Best regards, Miha
  2. Hi everyone, for this contest I realize a bridge layer's tank, inspired by the Titan tank. The funcion are: R track - XL motor L track - XL motor Stabilizating turret (up and down) - L motor with one big linear actuator Bridge layer arm - M motor with two big linear actuator The model is quite finished, just the last touch up and the last photo/video... Follow a preview, hope you like it!
