Showing results for tags 'baja truck'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Once i wanted to make a baja truck, and i failed. though as you should do in life, i stood up and tried again. and suddenly, i had a frame. and a 'little' later i had a baja truck. fuctions: Full suspension: Front; double wishbone (travel: 1.5 studs) Rear: live axle (travel: 5 studs) RTC steering (Servo motor) RWD (XL-motor) Full RC I started making a front suspension which had to be soft and a good height clearance and RTC stearing. After a while i had a very sturdy stearing module, so i started making the rear axle.The XL motor is mounted on the live axle. it has a 1.66:1 which gives it a speed of 243.4 RPM and 8.7 N.cm. of torque. I used the short steering link to make the suspension freëer then used the 3X5 L links to connect to the springs. The battery is pretty high above the center of mass, but it doesn't affect the performance weardly. the IR receiver is possitioned just under the widnshield which makes it pretty easy to reach. The body is made out of 3 pieces, The bumper, a nose scoop and the rest of the body. the body is connected in 14 points to the chassis, the scoop only at 2 and the bumper in 6 places. I might do instructions on the chassis, but i don't know if i will on the body (only if enough demand). Greetz TNLD more pictures:https://flic.kr/s/aHskvfPA6Y LXF file of the chassis: http://www.mediafire.com/file/2w3uet74f11bamk/Baja_Truck.lxf
