Showing results for tags 'babylon 5'.
B4 is scaled to my B5 station MOC (see final pic), but unlike B5 this one is not intended to be possible to build! Some parts are not available in those colours and the three main components are floating in space (pun intended), not connected. It wouldn't stand up to gravity, either... 🤣 In the show, the internal cylinder and outer shell counter-rotate and the arm/solar panel framework in-between is static. The reason Babylon 5 was even built is that Babylon 4 was stolen the day after it went online and sent back 1,000 years in time to serve as a base for a war against the Shadows (the big-bad of the B5 story). Some statistics below: Studs: 179.1(L) x 124(W) Inches: 56.4(L) x 39(W) Cm: 143.3(L) x 91.9(W) Weight: 22.3 KG, 49.1 LB 25,006 parts. More pics in my Flickr album.
It was the dawn of the third age of mankind – ten years after the Earth-Minbari War. The Babylon Project was a dream, given form. Its goal: to prevent another war, by creating a place where humans and aliens can work out their differences peacefully. It's a port of call – home away from home – for diplomats, hustlers, entrepreneurs, and wanderers. Humans and aliens, wrapped in two million, five hundred thousand tons of spinning metal . . . all alone in the night. Hi, all. You may have seen my earlier WIP thread where I said I wouldn't do this, but I was persuaded to change my mind. I have finally completed the instructions for my MOC tribute to Babylon 5. They've been proof read, improved and tested out several times (oy!), and you can now purchase them through Rebrickable here. If you have the space for a UCS Star Destroyer, you have the space for this - there's no excuse not to, really... Model Statistics 6,700+ parts113.2 x 24.4 x 38.7 (cm) 44.6 x 9.6 x 15.2 (in) 141.5 x 30.5 x 48.4 (studs)~4,680 (g) ~165 (oz) Some more pics: Instructions sample - small by David White, on Flickr B5 with Stand and UCS Plaque by David White, on Flickr B5 UCS Sticker by David White, on Flickr
- 6 replies
- babylon 5
- instructions
(and 1 more)
Tagged with:
The Babylon Project was our last, best hope for peace. A self-contained world five miles long, located in neutral territory. A place of commerce and diplomacy for a quarter of a million humans and aliens. A shining beacon in space . . . all alone in the night. And if you're curious how big this is: Currently she sits at ~6300 parts; ~4kg weight; ~142 studs or 113cm long; 45 studs or 36cm height, ~25 studs or 20cm wide... Check out more on my Flickr! Built in LDD (modded with the additional parts pack - there are no collisions), then imported, fixed-up & rendered in Stud.io. I haven't figured out how to use Stud.io's renderer properly yet, so these shots have really basic lighting, etc. For details, colours & general inspiration, I'm using the awesome renders by this guy and reference images from here. It's surprisingly close to those last reference images! I also bought the 20 year-old Revell model kit recently as further reference IRL. Structurally, the cylinders are mostly based on the Saturn V internals, and it's built in interconnected modules, not along a single central spine, which works great digitally but might not in real life! Oh and there's a studless Lowell sphere at the front, of course. I started sketching this out in LDD 2 years ago then it went cold until about 2 weeks ago, when I picked it up and inspiration hit. Next steps will be to design a multi-point stand - she'll need a lot of support in 1Gs worth of gravity. Then test builds. I'm sure she'll evolve in that process. Before anyone asks, because cloners stole my Agamemnon design there won't be instructions or shared LDD/Stud.io files for this one - pics only!
Back in 2004 I built an Omega Class Destroyer from Babylon 5. As the 10030 Imperial Star Destroyer was released 2 years earlier, I chose the same scale: 1:1600. It stands on my bookshelf for years, hence the pictures. The small ships on the bookshelf are a true to scale Earthforce One from Babylon 5 and a nearly true to scale F-303 Prometheus from Stargate SG-1. I did a lot of research, collecting multiple screenshots of Omega Class Destroyers to get the correct proportions an details but the most important reference was the PTEN model: Some details look a little bit odd today because a lot of bricks, that are common now, weren't available in 2004. For example, the round structures in front of and behind the rotating section consist of slopes. Today I would build them with rounded slopes. Unfortunately I cannot just change the bricks because the Omega Class Destroyer is built completely with old light gray and dark gray bricks. (The six 75 degree dark gray inverted slopes at the front were goddam rare and aren't available even on Bricklink nowadays.) A special challenge was the unavailability of many SNOT-bricks in 2004 as at that time the only SNOT-bricks available were the headlight brick with the setback SNOT and a 1x4 brick. It was a hell of trial and error to get the correct gaps between the 12 red missile pods. Hyperion Class Cruiser an Narn Heavy Cruiser of same scale to come...
Hi, folks. During last SHIPtember, Ryan Olsen created a SHIP based on Babylon 5 - the EAS Agamemnon. I stumbled across it at the time thanks to some Lego blogs, and at the end of the year decided to build one for myself. Credit for the original Lego design goes to Ryan, of course! I took his WIP pics (here) and final pics (here - awesome photography & Photoshopping!) and reverse-engineered it in LDD to understand how it all held together and what parts were required. Then I used Rebrickable to figure out what parts I needed. To build it, I used the "hide" tool in LDD - hide bricks in reverse order, then undo to play back the build as you follow along. Much more helpful than the absurd LDD-generated instructions... Here's the end result (Flickr album here) - my pics & lighting are not studio-quality, unlike Ryan's! The middle section rotates (manually) and stays put at any angle, so it's well balanced and the turntables provide enough friction to keep it stable. Stats-wise, it's about 95cm (~117 studs) long, 35cm tall and 15cm wide, using ~4700 bricks, weighing-in at just over 3.7kg (8.2lb). I made some guesses as to internal structure (e.g. the turntable connections in the rotating section) and the greebles on top & bottom are my own, but it's very close to Ryan's original design and some reference images of the original. Ryan was kind enough to share the image files he used for the stickers, so I was able to complete the model. I couldn't connect the front & rear side plating in LDD - as I learned here, the connections are just illegal as there's not enough clearance between the side plates and overhanging top & bottom plates in software - however, it obviously works in the brick. I converted the LDD to an LDraw file (using SylvainLS's updated parts mapper here) and used LDCad (which can ignore collisions) to place the plates in order to use POV-Ray to make the renders you can see in my album. I learned a lot doing that! Note that I made some tweaks in-the-brick but haven't re-done the LDraw file or any renders to reconcile the minor differences. It was a fun, frustrating at times, but very rewarding journey, and I'm really happy how it turned out. The SHIP looks awesome on display in my living room. Thanks for the inspiration, Ryan, and thanks to those on this site who helped with the digital stuff! Here's a 360 degree render: https://photos.app.goo.gl/caouE0BlHzarD6C42
As requested by Inkpanther in my last thread on the EAS Agamemnon, here's another B5 MOC! This time it's just in LDD/LDraw, but the renders give a pretty decent idea of how it might look IRL. Front (got guns?): Side (oh yeah, don't forget the missile launch tubes as well as the guns ): Top shot (new greebles, new parts, another view of dem guns): If you're familiar with the reference material, or if you've seen the other thread, the Nova-Class Dreadnoughts are predecessors to the Omega Class Destroyers - without the rotating section but with a ridiculous quantity of guns and slightly fewer Starfuries. This beastie is for takin' names and kickin' megablocks. As a result, it wasn't much work to translate the Agamemnon into what I want to call the Schwartzkopf. The reference images I used are the Antares, but I prefer the one that was a topical reference (well, it was at the time!) to Stormin' Norman. Stats-wise, this one is 104 studs long (still legally a SHIP, right?), 30 tall and 20(ish) wide - or about 83x29x16cm. It contains 3720 parts, almost exactly 1000 less than the Agamemnon. I don't think I'll build this one in the brick (I'd have to make a UCS plaque) but just in case, I put the plaque holder on the opposite side of the stand from the Agamemnon so that they could face each other head-to-head on display at home. The model has 5 not 7 "ribs" in the midsection compared to the reference shot of the Antares but I'm fine with that - it fits my scale better so I'm taking artistic license. After placing the side-panels in the LDraw version, I can tell there could be some brick alignment issues with them around the midsection that would require a minor redesign of those, but they could probably do with a minor tweak anyway. The full Flickr album is here. As well as the renders there are a few reference pics I cribbed from the web, including a side-by-side comparison of a Nova and an Omega. Hope you enjoy it!
