Showing results for tags 'air ride'.
This is my first WIP thread for a vehicle I've wanted to create for some time now. The most difficult part of this build so far has been the air ride. When Air ride is at its lowest or highest point, it clicks. This also lets you know when to stop lifting so it doesn't over rotate and jam the gears. I placed the 1X1 angled black system Lego on the L shaped beam, so the drop is only 45ΒΊ on the axle. Then I noticed the weight of the car might not be able to hold the body work up so I added torsion bars to all 4 wheels. This design can be setup as 4 wheel steering, because the front suspension is exactly the same as the rear. (But the SUV I'm building doesn't have that function, so I opted out of it ) This beast comes stock with a V8 engine, air ride & torsion bar suspension, servo for steering, 2XL motors for drive 2M-motors for lift. I had to hide the servo in a different place as the axle for 4wd goes through the center. I am trying to get the steering wheel working but its tough... SUV framework for my new MOC by lachlan cameron, on Flickr I've been working on this frame for 2 weeks and am happy with how well it functions. I placed 3 pounds on the framework and the lift still works. SUV framework for my new MOC by lachlan cameron, on Flickr 2 M-motors are geared down before they turn 1 worm gear on each wheel to lift the whole vehicle.
After 1 month of building this beast I'm proud to present Dug's build that is completely modular, has 1 l-motor to raise the rear wheels and 2 m-Motors to raise front wheel 5 studs higher, 1 servo for steering and 2 XL motors for drive, working V8 and fan at the engine. Designing and creating this truck was the most satisfying so far. 77 studs long x 39 high x 23 tall (slammed) Weight: 3kg = 6.6 pounds https://flic.kr/s/aHskCMJtR4 Slammed ride 100% modular Rear air ride
- 21 replies
- air ride
- mechanical
(and 4 more)
Tagged with:
