Showing results for tags 'ME track'.
A little history: I was about to pull the trigger on the altBricks track. I literally had the content uploaded to Kick Starter but needed to tie up some loose ends before posting and then, BAM, the ME KS project was public. But alas still no metal track... I considered releasing the altBricks version at the same time but worried that the ME KS project already tapped the funds of the LEGO train enthusiasts. I figured out a way to make metal and plastic track relatively simple in one mold for all 4 curves (or 3 curves and 1 straight). It's a one piece track sections (like LEGO track) that is 100% connector compatible to LEGO track. The beauty of the altBricks system is that one simple machining process on industry standard HO nickle silver rail satisfies any radius curve or straight length. I made prototypes, a half dozen of these straight tracks and a 1/4 circle R88 (I think 8 segments) using ME rails and they all work fantastically. I would continue to do this for my whole home layout but its a big pain in the butt to retro-fit plastic rails and you tend to mess up 1 out of 6 times destroying the plastic track. The question now is do I make this process public domain? If so, I hope that if someone runs with the idea they pay me 3 full circles of each radius and some straights as royalty :-) Or should I do a Kick Starter project and have altBricks do this? A better idea is if the ME guys would agree to talk with me, they are the most logical company to do this and this solution can work in their system too. And my royalty seems pretty reasonable. :-) Your thoughts? Thanks, SteveB altBricks
