Showing results for tags 'Lego fortress'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. This modular castle system is based on 4x8 and 8x8 modules. They are designed to connect in all 3 dimensions so you can build walls, towers, keeps and fortresses. Below is an example of a smaller castle that you can build the interchangeable modules in about a Minute (minus the time for the decorations). Modular Castle Two Towers by Michael Kalkwarf, on Flickr Pictured below are the room modules. They connect to each other by using the pair of Lego Technic pins on the side near the top or by stacking them. They can be placed directly on top of each other or offset by half a module (4x8) [Herurl=https://flic.kr/p/AfPp6R]Lego Modular Castle room modules[/url] by Michael Kalkwarf, on Flickr Here are various versions of the half or 4x8 battlement modules. They clip into the top of any room, balcony or bridge module. Lego Modular Castle Half Battlement modules by Michael Kalkwarf, on Flickr The modules below are the bridge and balcony modules. They each come in half, 4x8 and whole 8x8. These connect to the room modules using the pair of Lego Technic Pins. Once connected they extend the top surface area and allow you to place any room or battlement module on top. Lego Modular Castle balconies and bridges by Michael Kalkwarf, on Flickr To see a video demonstration of this system go to Below are a front and back view of a hybrid of the balcony and bridge modules. They use the pair of Lego Technic pins to clip into the corresponding pair of pin holes on any room or bridge module. These match the floor level of the module above to allow a decorative balcony or curved battlement. Lego Modular Castle curved battlement and balcony by Michael Kalkwarf, on Flickr If you want to top off a tower with a decorative roof instead of a battlement, the roof and height extender module go together well. Lego Modular Castle roof and extender by Michael Kalkwarf, on Flickr Next is a view of the bottom room modules. Here is a front and back look at 3 different versions. The one in the center is a corner piece. Typically these bottom room modules are used to form the bottom level of your castle. These modules also have the Lego Technic Pin holes that allow you to connect any two modules together. Lego Modular Castle bottom Modules by Michael Kalkwarf, on Flickr Below are 2 different whole or 8x8 battlement modules. These can be placed on top of any room module, bridge or balcony. Lego Modular Castle whle Battlement Modules by Michael Kalkwarf, on Flickr Here is an example of a larger castle that you could build using this modular system. Lego modular castle 16 by Michael Kalkwarf, on Flickr Here are a couple of smaller ones. The possibilities are endless. Modular Lego Castle two watchtowers by Michael Kalkwarf, on Flickr Modular Castle Central Tower by Michael Kalkwarf, on Flickr If you are interested in seeing more castles built from this system as well as how the modules connect to each other. There are more pictures on MocPages. http://www.mocpages.com/mocs.php?id=120740 I have submitted this modular Lego castle system to Lego Ideas as the Kingdoms Modular Castle. If you like this system, please vote for it. https://ideas.lego.com/projects/116214
