Showing results for tags 'Fortress of Solitude'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. Hello, and welcome to my minifig-scale bottled city of Kandor! This is the first MOC I've posted on EB, so be gentle. Or harsh. Or honest. EDIT: I may update this later, as I keep building, or take better photos This is part of a much larger Fortress of Solitude project I've been working on since forever (hence WIP, or work-in-progress). Please excuse the dust, dog hair, bad lighting, bad photos, etc, etc, ad infinitum. I'm only posting because someone asked how I did it, and because I really like some of the work I've done and am keen to share it, even if I'm not in a position to take decent photos. Or dust thoroughly beforehand. Seriously, my dog sheds a lot. It's a problem. On with the show. Here's some shots of the city, still bottled. Each shot is a 90 degree rotation clockwise from the previous shot. And here it is out of it's bottle. As you can see, the city is built on a 2x3 plate for a base, and fitted into a 4x4 (round) space, offset using two jumper plates. This is pretty tricky. The top of the cylinder, when assembled, only has a 2x4 opening, so you can't simply put the city inside the bottle. The opening at the bottom is the same 2x4, so you can't attach the 2x3 city then add the half-cylinders because the city overhangs on at least two sides. The easiest way to assemble it all is to add the two 1x2 jumpers to the bottom of the city's 2x3 base, then hold the cylinders around the city, so that the cylinders grip the jumper plates and form an even surface. Then attach the assembly to a 4x4 (round, or not), making sure to apply pressure to the half-cylinders AND the city itself. This can be frustrating, especially if the city isn't stable enough to withstand the pressure put on top. For mine, that longest spire is a perfect place to apply pressure and ensure solid clutch-power on the bottom. As for the city itself, well, you have tons of options. I went for the white color-scheme, to match the general aesthetic of the 70's movie version of Krypton, but plenty of depictions of Kandor/Krypton have color, so it all depends on what you want. For my project, I just started grabbing all of the tiny white pieces I could find in my collection and started throwing them together, finding pleasing arrangements, hoping to suggest micro-scale alien architecture. This is the fourth version or so that I came up with (though I think I liked the second version better, it is lost to me now). Here's some shots without the bottle, each one turned 90 degrees clockwise, as before. As you can see, there's all sorts of tiny bits in there, lightsaber hilts (attached vertically using a 1x1 round w/ pin), a lever-base, cheese slopes, a skeleton arm, some minifig hands, and lots of SNOT building on a 1x1 brick with studs on 4 sides. There are so many ways you can configure this stuff, it's nuts. I actually just acquired some white minifig skis that I'm hoping to incorporate soon. The only restrictions are to the inside of the cylinder, which leaves some room to build past the 2x3 plate-edge on the short sides, making the city more rounded in appearance. Spires also need to be position to fit through the centered 2x4 gap at the top. That's it, really. If anyone has any questions, please let me know! Now that that's out of the way, here's some shots of the Fortress itself (very much a WIP), and a couple of other goodies. A wide shot of the base and half of the outer Fortress, with Kandor sitting in front for size-reference: Pictured are four spires, individual constructed and attached at the base. The spires are built using a core of standard bricks and technic bricks, strategically placed so that the outside can be plated and tiled in various places, adding to the crystalline look I'm going for. Here's where the spires attach, using some technic pieces, so that the spires are able to swing open, allowing access to the interior (which is fairly non-existent at this point ) The spires are built with some overlap, so that, if you raise the first one, it catches the second, and so on. When closing it up, the last one catches the next-to-last, and so on. Aaaand, this is the point at which I stalled out on the project. I want to incorporate some gears so that the entire structure can be opened and closed using one crank/gear. But I'm not a Technic guy. I came up with a simple enough lift system, but the spires are too heavy for it to work smoothly, or well, or at all really. I thought about redesigning the spires to be more hollow, thus lighter, and I thought about changing the way in which the spires interlock, and I thought about changing.....etc. So yeah. That's why there's a year's worth of dust on this monster. I should get back to work soon. Again, criticism, thoughts, and ideas are all welcome. Here's a case of kryptonite that would go somewhere inside, though I'm not entirely happy with it, simply because glass isn't enough to save Superman. It'll have to go behind lead, but then we couldn't see inside, so I'll probably add a vault for it to go in. Eventually. And last but not least, my Phantom Zone projector. I styled it largely based on the Superman: The Animated Series version. It is able to tilt up and down on the stand, or detach completely so that Superman can fly around with it and zap anyway who annoys him. Like Jimmy Olsen. Damn that Turtle Boy! A picture here would be good. #FAIL Phew, I'm tired of writing this post, so I guess that's it. Thanks for checking it out!
  2. Hello all, For my latest MOC I wanted to build something totally different from what I'd built before; both to confront new challenges and to avoid comparisons. (not to mention a serious depletion in bricks in a lot of key colours after my last build hugely limited my colour selection!) So this is my LEGO rendition of the Fortress of Solitude, based on its depiction in the original Superman movies. For anyone not too familiar with superhero lore, the Fortress of Solitude was created with a shard from the Planet Krypton and hidden in the remote Arctic.It's Superman's home-away-from-home. The model used 18,684 pieces, took 160 hours to build and was completed last week. To see more of this model and my other models, go to: Janet VanD's Gallery
  3. Hey guys, Just wanted to share my latest LDD MOC: Superman's Fortress of Solitude. I tried to combine elements of the Fortress of Solitude as seen in the movies and "Smallville," so it has a crystalline exterior--but also put in features seen in the cartoons and comic books. So there are things like a shrine to Krypton, Kal-El's "Baby Rocket," a trophy room, and a Kryptonite vault. I added some minifigs and a villain attack vehicle to make it more like a "real LEGO set," and after getting encouragement from some friends, decided to put it up on CUUSOO. If you're interested you can check it out--link is in my signature. Anyway, here are some pics:
