Showing results for tags 'Brickfair 2014'.
Hello all: As promise,d here are some photos of the layout I presented at Brickfair 2014 in Manchester, NH. I decided to go with a working cargo yard, patterned loosely off of the operations of the Maine Central railroad in the later 20th century. The cargo trains for MEC (often pulled by a GP7 od the type I built for the layout) regularly hauled pulpwood (non limber grade) logs to the state's paper mills. So I tried to capture some of that quintessential railyard activity while also keeping the layout fun for all ages. I hopu you like it! Some overview pictures: The signal tower was loosely patterned after PT Tower in Rigby Yard, South Portland, ME. All buildings have interiors. In a concession to time I chose only to MOD the 60059 logging truck: I built a new back end with a second trailer. The shed is bullt on a single extra-large gray baseplate (48 studs). It sits on an elevation of about four bricks -- for reasons that will be apparent soon!. The shed roof comes off in two pieces, like the Simpsons House roof. There is a center beam that holds the "cupola" area. You may notice my homage to the 10027 train shed tools. Ooops! An 8-wide flat and two six-wide boxcars that I built (with help form m 10-year-old son) to fill out the layout. The pink hobo was a last-minute addition. I am very pleased with this bulkhead flat, depicted here being loaded with pulpwood. Get back here, bacon! Hope you enjoyed it as much as I did building and showing it!
Hello, friends! I'm pleased to present my first custom train MOC, a representation of an EMD GP7 in the livery of the Maine Central Railroad (MEC). The Maine Central Railroad operated passenger and freight service in northern New England for roughly 100 years. It's main line, running between South Portland and Bangor, Maine, passes within a half-mile of my house. The particular engine I've chosen, the 573, was purchased new by the railroad in 1950. It was favored by the railroad's longtime president, E. Spencer Miller, and was often used to pull the MEC "business train." Outside of that operation, the GP7s frequently hauled pulpwood and other cargo to and from the region's paper mills. Here are some source photos I used in the design and building process, courtesy of the RR Picture archive: http://www.rrpicture...e.aspx?id=11524 And here is the MOC. She's 8 wide at the cab and 42 studs long. Powered with the standard train motor; there is plenty of room on the inside to add a second motor and polarity switch, once I have enough rolling stock! (This is the best shot of the top I have -- sorry for the poor quality). I built this engine as part of a larger working yard layout that I exhibited --my first time ever-- at Brickfair 2014 in Manchester, NH. (I'll do a separate post on the layout soon). I was honored by and very appreciative of the nomination for one of the exhibition awards, which was ultimately won (and deservedly so) by ShaydDeGrai's wonderful and mammoth representation of Barad-dur. The time crunch to get the exhibit finished in time forced me to cut short some of the finishing touches on the engine. I'd like to add working lights, which will require a redesign of the front and back of the engine, probably with cheese slopes instead of the current 45-degree sloping bricks. And I also need to "fix" the platforms at either end, adding stairs and replacing the buffer magnet assembly with free standing magnets and train. Decals to really finish off some of the logos and paint treatment would also be nice. One final note, the 573 is still in use today. The MEC closed in 1981 as part of a merger with Guilford (now Pan Am). The 573 went through a number of transfers within those rail networks until it was purchased in the 1990s by the Conway Scenic Railroad. Today the 573 hauls excursion trains for tourists. Here it is in its current livery (perhaps a future project), enjoying its active retirement gig: I welcome your comments, criticisms and suggestions. This site has been invaluable as I have journeyed out of my Dark Ages and into the new world of L-gauge. I'm still a novice in the world of train design but all journeys must start somewhere... - MBF
- 16 replies
