Showing results for tags '917'.
So i finally got the new 917 919 set, and being a huge fan of the 917 i knew i'd have to mod it to make me completely happy but i didn't realize just how much it would need it. below are 2 pictures top one is mine in front of an unmodified 919 (its 3 plates taller than my 917!) the second is a borrowed image of a standard Lego 917. the drop was achieved by 2 things primarily, first i lowered the canopy down 1 plate, and the second was switching to smaller tires/rims this took off a second plate (it was already 1 plate lower than the 919) there were also numorus less obvious changes inside and out to achieve the end result. My Modified 917 Lego's 917 Front View, showing narrowed front opening and reshaped nose. also the one downside to the older fender, the gap rear of the front bricks Rear View, here you can see i added some greebling to fill out the space better, also the tail lights were removed as the were just way to big on the standard car. If you look close here you can see through the canopy to the driver, he is leaned back a very long ways to fit, and this was a trick. the driver sits so far forward in the real car that the minifig legs should actually be placed where the wheel hubs are located. so the standared chassis has been thrown aside to move the driver cavity forward as far as it could go. also if the helmet is removed he can sit quite a ways up further. simple side by side, you can see quite a noticeable height difference between the 2 cars. So there you have it a still speed champion styled Porsche 917 but much better wheels height and shaping in my opionion, feel free to comment, suggest, or anything. and Thanks for looking!
