Showing results for tags '75155'.
Hello everybody and nice to meet you, I'm a new member on Eurobricks, I presented myself a few days ago here! Today I try to open my first thread, and doing so I would like to show you those creations of mine. They are not exactly mocs, as they are based on official sets, but they are sort of modifications I considered necessary to improve the original Lego models. Down here you can find the pictures of the Tie Fighter, a couple of posts below you can see my modded U-wing! So, let's start: [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr There are more modifications than you can probably see at a first look. First of all, the wings: black stripes have been placed on the inner side of the wings, and the outer black plates has been replaced with tiles. Inner and outer stripes has practically the same angle, so they blend easily in the model. Horizontal lines are realized by using 1x2 jumpers, diagonal lines with longer tiles, and are kept in place only with a 1x1 plate that allows the rotation of the elements. They are not very sturdy, but are more than enough if your plan is to show the model only on the pedestal. There were also some dbg plates in the wing panels, I replaced them with lbg to uniform the color. Moving to the cockpit, a big part of the curves have been redesigned to improve the sphere effect. Lego designers were clearly forced to create a playable solid model (and to include the horrible springload shooters), limitation I didn't have, so I could replace some pieces to improve the geometries and collocate the red parts in a more trusty way. I also used two small red stickers to create the right angle, but it hasn't been a so good idea, probably. The front printed round element has been rotate by 90 degrees to blend its joint with the red section. In the future I will probably replace the whole piece with another withound the joint (does it exist?) and in a different color, because I don't like the choice to use a transparent red piece. Another modified part is the joint of the cockpit with the wings, where I used some grill 1x2 tiles instead of simple 1x2 black tiles, as the real model shows far more lines than the actual set. Also the antenna has been simplified with smaller pieces to respect the right proportion with the ship. [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr The rear of the model has been totally redesigned, as you can see in the previous pictures. The engines on the side are definitely bigger and more protruding than the set's ones. Take a look at the end of the post to see a comparison with a toy model. I'm not sure about the red wake I included, but it's definitely nice! There were also some visible technic parts that have been covered with black tiles. In the following pictures you can see the shape of the edge lines, more rounded both in the lower... [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr ...and upper side: [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr To achieve that, on the upper side of the cockpit I replaced part of the plates with tiles or slopes because I personally don't like visible studs. Lastly, here it is the pedestal I created with spare technic parts. It is not adjustable as the one you can find in the UCS model, but keeps the fighter in a good angled position very nice to be exposed. The minifig will be replaced with the special forces pilot as soon as I will buy the new Kylo Ren's Tie Silencer. Another possibility would be to place, insted of the pilot, the characters who used this ship in the movie, Poe Dameron and Finn in the stormtrooper suit. [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr [MOD] First Order Special Forces Tie Fighter by SpaceBrick, on Flickr Thanks for reading, if you want to leave a comment you're welcome! I will listen carefully to every advice and possible improvement you wanna share! p.s.: Down here, instead, you can find a couple of pictures of the toy model I used as reference and the actual Lego set:
Excited to share my first mod on a set; the U-Wing! It's small compared to other efforts, but I'm just getting started. I'll also have a video if I'm allowed to share that. Anyway, I've added a second pilot seat, removed unnecessary technic to allow more space in the transport, and extended the wings from 40 studs long to 44 studs long. Then additional greebling, replaced stud shooters, and changed the rear top behind the cockpit to remove the pop open feature and add detail. I would love to hear thoughts and feedback! Thanks! Removed the cockpit pop open play feature to add detail, greebling and accuracy. Since I wasn't changing the base hull of the ship, I took inspiration from the Republic Gunship to add a second pilot seat. Another view of the two pilots. The additional pilot now "floats" in the lower window. A very simple dark gray plank with a slope piece for flare allows a second pilot without altering the width of the set. Underside view of the transport window showing additional plank for second pilot. Larger view of underside. The transport with the second pilot fitted on; stud shooters have been removing, now acting as weapon racks, and technic poles have been removed to free up some space. After removing the technic bar a simple detail piece from the Millennium Falcon was placed in the center. Closer view of the pilot The original printed tile was placed on a flat piece to free up space, and two additional yokes were added. An upright view of the yokes. ___________________________________ May the Force be with you!
I have been modifying my lego 75155 u-wing fighter I always thought that the cockpit was too narrow as it should have 2 abreast seating and the control deck should be linked to the load / troop area hope you like it any ideas to improve are welcome i used 2 x 75155 sets plus some other bits and pieces I dont have any building instructions as i built it up as i went adding and modifying from the standard instructions from 75155 https://flic.kr/s/aHskNnjwfh
