Showing results for tags '7-seater'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hi all, I present you my finished MOC of a 7-seater familycar with full functions: DETAILED PDF INSTRUCTIONS NOW AVAILABLE HERE, REBRICKABLE ENTRY HERE Separate PDF instructions for the roof implement available HERE, Rebrickable entry HERE I got the idea for building a family car about 3 years ago, when looking for a bigger car IRL for my own family. I was intrigued by the fancy seat folding mechanisms seen on these type of cars and wanted to reproduce that. For the model, I took inspiration from the Ford S-Max, which in my opinion combines good looks with all familycar requirements. It also comes in some fast versions, so it is fun to drive as well (unfortunately, IRL this car is well above my budget... Ah well...): It was clear to me early on that I would not be able to reproduce the exact looks (I'm not that good a scale model builder), but I wanted to stay as close to a real life car as I could in terms of mechanical features and looks on both interior and exterior. Meanwhile I wanted it to be structurally sound as well, based on modern "box structure" car frames. I built numerous iterations, starting in 1:8 scale, and later switching to 1:10 scale after having to much trouble with the larger scale when it comes to chassis stiffness. I have worked on this on and off for over 2 years, finally resulting in this build. The model has: 5+ R gearbox with linkage control: full suspension (independent McPherson with drive in front, dead trailing arm axle in the rear): 4-in-line transversally mounted fake engine in the front: rigid box structure chassis full interior with adjustable/folding seats on all rows: Folding the seats movie opening doors (with lock), boot and hood: parking brake (transmission lock) I wanted the maximum available interior space for this car (that's what a family car is all about after all...), so I set myself some goals: no supports from bottom to roof inside interior space: center console should be no wider than 5 studs: front wheel drive with front engine and gearbox: I wanted to create a rigid chassis, which would not bend and is self supporting. Because I wanted as much interior space as possible, the bottom structure is only 2-3 studs high. I couldn't fit vertical frames in there (as they are 5studs high), so in the end the roof became an active part of the structure of the chassis. It is very strong and stiff, when one wheel is lifted, there is hardly any bending in the chassis, instead the opposite wheel suspension is compressed: The whole car can be lifted safely with only one finger, from the midsection on the roof and by the B-pillars and C-pillars: Here are some more pics: For a full gallery and all WIP photo's, check my bricksafe folder. ============================ Below and further in this topic is all the WIP progress of making this car from July 1st onwards: Pic of current chassis WIP with parking break (back yellow knob), gearstick (in front of parking brake) and linkage (beneath and in front of gearstick), and start of gearbox mounting and front suspension (McPherson with drive from Sheepo's MPS)
