Showing results for tags '42152'.
Hi folks, I want to share a new creation. Rebuild your Lego Technic 42152 Firefighter Aircraft into this Conwing L-16 Cargo Seaplane alias "Seaduck" from the famous cartoon Talespin. This model is an alternate build, meaning all 926 required parts comes from the main set with no extra parts needed. The plane uses 4 spare parts, that are all available with the set 42152 Firefighter Aircraft with a total parts count of 930. Get ready to join the Higher for Hire Cargo Company with its pilot Baloo von Bruinwald XIII, to rebuild one of the most iconic planes in cartoon history. You can find instructions here if you are interested in building this model. Features & Functions fast spinning propeller in opposite direction working rudder on wings openable cargo bay with linear actuator dual-linkage mechanism for cargo doors implemented wheels for comfortable playing includes two offshore buoys measures 40x46x12cm Impressions Propeller & rudder Propeller for that seaplane are custom made to fit the scale of this alternate build. Both propeller are geared up as much as possible, spinning very fast but smoothly in opposite direction by turning the red gear on top. I was not happy about the rudder implementation for the Firefighter Aircraft donor set. As a result, the rudder on wings are operable in a more comfortable way for this model. Cargo bay & doors To be confirm with the Higher for Hire Cargo Company, this Conwing L-16 is made to transport freight, providing as much space in the back as possible. By controlling the black gear behind the nose, a linear actuator is triggering a sliding mechanism to open the cargo doors. This mechanism opens the cargo door itself and part of the roof simultaneously, providing more room to reveal the cargo bay. The following animation should help to understand how the dual-linkage mechanism for the cargo doors works: Floating over surfaces This model is made as a seaplane only with no retractable landing gears, due the fact that the linkage mechanism inside takes up almost all the space. Thanks to the implemented wheels, the plane floats very smoothly over each surface to ensure a good playability. Of course this Conwing L-16 is a construction toy, do not put it into water. This model does not really float on water, but on its wheels instead. The seaplane has a heavy back wing like the real one, performing a take-off when displaying the model. Instructions Premium instructions for this alternate build comes in a single PDF-file with 241 pages of high quality building steps and clear images to ensure a satisfying building experience. Builders will be surprised what clever techniques and tricks are used to form all the shapes of the model, especially for the iconic red nose. Go back to the basics of Lego Technic with common colors, cool functions and playability - not only for the younger audience of builders. You can find instructions here. Seaduck from Talespin Talespin is a trademark of Disney and freely used to reference this model. Have fun with this 42152 Conwing L-16 "Seaduck" Cargo Seaplane alternate build.
- 9 replies
- alternate build
- alternate
- (and 5 more)
