Showing results for tags '42035'.
Around 4 months ago I built alternative model of 42035 Mining Truck but I just found some spare time to take pictures, film and describe it. So, using only parts from one 42035 set (including spares) two models were created: single engine Airplane and Tug. In total I used 347 parts from original 364. Mostly long axles and connectors has left. AIRPLANE This one has been built first. First off when I saw tapered panels I thought – “they’ll fit perfectly as an airplane wings!”. So I had no doubts what kind of alternative I’d like to do. Alpha version was created in 3 evenings and didn’t differ that much from the final product but still many parts left, including 4 wheels. I thought that it’s too much waste of bricks and I have to think out something else, best if this “something” would fit existing model. And so, second model appeared - Airport Tug, but about it in a minute. Airplane consist of 208 elements. It has moving single piston engine and propeller at front. Movement comes from rear wheels which are made out of T16 entwined with a chain. Plane has also movable rear loading ramp and ruder. From visual site there are pair of landing lights and side exhaust. Cockpit and 4 windows for passengers were highlighted too. TUG As I mentioned earlier after building airplane lots of parts left and I’ve made second vehicle – tug. It consist of 139 parts and has 2 functions – driving and retracting rear tow bar with hitch. In this model you can detect 2 similarities to mining truck – front grill and steering system. As there were quite limited amount of bricks left, probably nothing better than this, which has been already made, was possible to create. As in original truck there is also HOG steering. Tow bar mounting point is exactly at the end of frame. To fold and unfold it there is T8 gearwheel placed just behind driving wheel. At its end there is a hitch for airplane front wheel that can moves freely in any direction. After hooking it up propeller doesn’t touch any part of tow bar. Thanks to short wheelbase and overall compact dimensions even with hooked up airplane, maneuverability is really good. Everything due to limited amount of bricks is outlined in shape of tug but whole construction is resistant for intensitive play. Unfortunately visual attractions and details almost doesn’t exist beside front grill, mentioned earlier, and headlights. Bearing in mind that there are only around 360 bricks to use I think that models are not that bad. Both of them had to go on compromise but more attention and parts I spent on airplane. VIDEO: INSTRUCTION: It is true that making instructions is not my strong point but this time due to fact that many of you has 42035 set, I decided to made a LDD model. You can download it along with automatically generated instruction by clicking: DOWNLOAD Before building note that LDD interpret "axles with stop" incorrectly, so it's sometimes impossible to place it like instruction suggest. Keep it in mind when building. Thanks
- 10 replies
- 42035
- alternative
(and 3 more)
Tagged with:
Hi there, Just discovered the C-Model index, and realized that I have a few creations I could add to the list... 'cause I love C models :) Here is one I did some time ago with the 42035 set. Instructions are available on rebrickable. This is a small quad, featuring a fake engine driven by the rear wheels. The rear axle is also pendular, and the steering works. Here are a few more pictures: Any comment welcome :)
Dear all, Here are a few pictures of a C-Model I did from the 42035 truck. When I bought the set, I thought there should be all enough to build a small motorcycle: Together with his little bro 8045-B: The motorcycle has exhaust pipe, a cap for the gas tank, some foot pegs. Pin holes of connectors mimic speedometers, 4-axle with stops suggests front lights. The model features 3 functions: Direction (!) One-cylinder engine driven by back wheel (16t + chain, 12t-20t) Sidecar's top opens via the spare wheel (16t-16t) For that last function, I could not use knobs as they are too bulky and prevent the top from opening wide enough. The sidecar can easily be separated from the motorcycle, as it holds by only two pins with friction. The sidecar has a small foldable sidestand. The one-cylinder engine is not centered (it is 2 studs wide, while the motorcycle is 5 studs large). The 20t is directly connected to the crank shaft, which allows the full thing to remain compact, a necessity at this scale. Here are a few more pictures: Any comment welcome!
- 4 replies
- sidecar
- one-set MOC
(and 1 more)
Tagged with:
