Showing results for tags '31313'.
Hi everyone, I'm Shah, and I like making models using just one Mindstorms kit. As I create new builds I'll add them to this post. Would like to share my latest MOC, a steamboat loosely based on Steamboat Willie. STEAMBOAT WILLI3 by Ahmad Sahar, on Flickr STEAMBOAT WILLI3 by Ahmad Sahar, on Flickr STEAMBOAT WILLI3 by Ahmad Sahar, on Flickr Short video clip and building instructions here. Hope you like it.
- 39 replies
- onekitbuild
- ev3
(and 3 more)
Tagged with:
Built to commemorate the Apollo 11 mission, 50 years ago today.
- 4 replies
- legomindstorms
- ev3
(and 4 more)
Tagged with:
Hi Eurobrick folks, I would like to present my first Mindstorm Ev3 creation: a combine harvester, which I named C-HARV3ST3R, following the Ev3 terminology. It is more than a year that the project was completed, and it stood for some time on a shelf before I finally made instructions (soon on Rebrickable). I then take the opportunity to present it here: It is remote controlled with the IR beacon, including steering and raising the unloader using the middle button. The header can be raised using a lever on the right side. There are two positions: when down (harvesting mode), the small wheels drive the reel. When up (driving mode), the reel does not turn anymore, and a lever push the touch sensor. The program can therefore "know" whether we are in driving or harvesting mode, based on the state of the touch sensor. The two modes differer by the following: in harvesting mode, the combine harvester drives more slowly and no reverse driving is allowed. In addition, a counter records how much we have harvested, a gauge (in %) is displayed on the screen at the top of the machine (where the actual tank is on real machines). When the tank is full, no further move is allowed and a "bip" is emitted. One need to either go in driving mode, or to unload the harvest by raising the unloader. In driving mode, the combine harvester moves faster and can move reverse (slow speed, emitting a warning "bip"). But a video is maybe better than words: Finally, just a few more pics: Hope you like it!
Few years ago I built Jason Allemann's LuuMa EV3 (LEGO Ultimate Useless Machine) and started taking it with me to local LEGO exhibitions. I found out that it has one structural problem causing frequent failures and in general it does nothing (since it is called "useless" it is not very surprising). So I got idea to modify it into switch that could control external motor. And I also wanted to fix that structural problem mentioned above. Now, let me introduce you LuuMa 2.0 - "LEGO Ultimate UseFULL Machine". It is improved version of original LuuMa EV3 built and programmed by Jason Allemann. His LuuMa didn't have any real use but my version 2.0 works as switch that can control large or medium motor connected to free cable in port D. You can see it in action in video bellow. Building instructions are available at buildinst.cz
Hi guys, Salut tout le monde, I'de like to share here some links to The NXT Step blog where is presented the ROBOT REMIX #1 challenge, where the MINDSTORMS team challenged some of the MCP (MINDSTORMS Community Partners) to come up with creative ways to remix a given Technic set and the Home edition of the EV3 set. for ROBOT REMIX #1 the Technic set is the brand new Sea Plane, a great Technic set that happens to be in the same color scheme ;) In this first post, is explained in a bit more details what is ROBOT REMIX http://www.thenxtstep.com/2015/08/robot-remix-1.html Then this week was presented the first of 4 remix, this one from master Isogawa http://www.thenxtstep.com/2015/08/robot-remix-1-exhibit-helicopt3r.html Stay tune for the presentation of the other 3 remix in the coming weeks. : . . baz
- MINDSTORMS
- TECHNIC
- (and 5 more)
Here is my model review of the Timmyton 5.5 robot shark built by Builderdude35. It is built using only one 31313 LEGO Mindstorms Ev3 set. Technical features: 1 programmable Intelligent Brick, 2 Large Motors, 1 Medium Motor, 1 Color Sensor, 1 InfraRed Sensor
- mindstorms
- ev3
(and 6 more)
Tagged with:
