Showing results for tags '10020'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 4 results
  1. Built by General Motors (GM) / Electro Motive Division (EMD) in 1939, this is the diesel that showed the way to the future, signaling the start of the diesel era. This particular engine (FT 103) was originally owned by Electro-Motive as part of a four unit demonstrator. After proving diesels were the superior to steam by way of a whirlwind tour of a whole heap of railroads, it was later sold to the Southern Railway and the lead A unit was eventually placed in the Museum of Transportation in St. Louis, Missouri where it resides today, under cover and out of the elements. (the other three units were scrapped before they could be preserved, sadly) My MOC is heavily drawn from the 2002 LEGO set 10020 - Santa Fe Super Chief. As that loco is a F7 from the same basic design as the earlier FT, not much had to be changed on the body outside of window placement and a few other things. The roof however, was completely revised to use the same design as 2013 LEGO Inside Tour set 4000008 - Villy Thomsen Truck. This was due to the needed parts as used in 10020 not being available in black in quantity. The rear of the locomotive. This model was first designed by me in 2013 in a very crude way (as seen on my Flickr here), but was heavily upgraded and modified over the years until finally being built last month when the final part - the windscreen - was released. The inside features the engine and control cab, and the roof is removable. Here is the real loco circa 2018, with the FT B-Unit from the Roanoke Transportation Museum behind the original A-unit. (This B-unit was at the St. Louis museum from 2015 to 2020 as part of a loan, but has since returned to Virginia.) Thoughts?
  2. Greetings, I have made LEGO 10020 on LDD with a yellow warbonnet and a B unit. I also have one in the blue warbonnet scheme and two other designs that use Earth blue . The point is that I'm afraid that Earth blue ,which is the most important color, will be hard and almost impossible to find in some cases. For example: 10020 Uses grilles and has some of those little doors (Part#: 3188/3189) and only one is sold from New Zealand in Earth blue. So my question is: Where do you guys get rare colors in large quantities from? (Example: Earth green, Earth blue, Medium azur, Aqua) ATSF F7 Yellow
  3. The EMD F7 was the SD40-2 of its day, the first true "common" diesel locomotive; thousands were built and could be found powering almost any train. When production had ended some 2,366 F7As and 1,483 F7Bs had been produced by 1953 just four years after the locomotive was first cataloged. According to an article by Don Strack, published in the November/December 1991 issue of "Diesel Era: Volume 2, Number 6" the, "base price on two cab units was $161,000 and the base price for two booster units was $147,500." This was also the first instance of the Electro-Motive Division's new General Motors Diesel (GMD) subsidiary filling orders. Read more from this article about this historic loco on this site. My model was inspired by the Union Pacific 1471 and 1476B pictured below. It was really the only photo I could find of a UP F7 A/B pair. My initial inspiration came after recently obtaining sets 10020, the Santa Fe Super Chief, and 10022, one each of the dining, sleeping and observation cars. I can see why they are so coveted, each is beautiful!I set about to modify 10020 in several ways to make it look better. I decided on the UP scheme because my dad left me his LGB scale UP loco when he passed (just like his LGB BNSF that inspired this build, here). I modified the sides and doors to more closely resemble the F7a and F7b units (which I'm presuming the 10020 was based on). While the windows are not round (yet) the vents between them, the doors, the grab rails, plus the square sand fill doors are all details I tried to capture more accurately than set 10020 did. Plus the battery box and fuel tank underneath look better. I decided to add twin train motors to the a-unit to propel it because my trains are heavy, my curves are tight and one motor just doesn't have the traction necessary (power yes, traction no). The PF receiver blends in nicely on the rear and the middle fan on top acts as a power switch. Seven of my eight locos have a concealed power "button" accessible from the outside, the Super Chief being my only one I have to remove the top on. Speaking of consistency between locos, my BNSF and CSX have a distinct side window look with the two vertical tiles. I'm considering that same look for my UP. The taped up windows look okay, especially from a few feet away, and while I like the slightly more detailed or scale appearance, the tape looks unfinished and I'm not sure it is necessary. I also applied minimal detailing on the inside. The b-unit got an engine you can see thru the windows and the a unit got a hint of an engine hidden in amongst the wires. The lettering and numbering I did myself on my inkjet printer using Testors decal paper. They are applied wet then they dry nice and smooth. As usual I'll share my LDD file for anyone who wants to examine, build or modify my design. I'll upload that soon. Here you go. https://bricksafe.com/pages/sed6 Hope you like! Edit: just realized I didn't print the X1471 decals that go by the headlights for the nose! Also in the pic above the stickers peeling off are actually just static cling stickers, they work well enough but show some bubbles and don't handle tight radius curves like on the nose. The final water-slide decals are applied in all the above pictures, except this one.
  4. Inspired by set 149 (Fuel Refinery) from 1976 as seen above (pic from BrickSet), this model takes the 4.5v era Shell refinery and turns it into a two-bay diesel locomotive / oil burning steam engine fuel depot for the modern PF age. The new refueling depot model features two floors with removable roof sections, two track-bays for servicing locomotives, plus a 1950's style tanker truck inspired by set 8486 (Mack's team truck, which hasn't been built yet.) The Santa Fe Bluebonnet model proudly uses no stickers, only printed parts. It's road number (327) is of a real-world Santa Fe bluebonnet engine, one that no longer survives after it's eventual conversion to a CF7 and scrapping sometime later. Sadly, all the Santa Fe F-series diesels were converted to CF7's, (whole body shell stripped away for viability reasons) and boy, were they ugly. Not many of the CF7's survive today, if any. As a side note, the locomotive bays are tall enough to let any official car through, including the double stacked container car from the Maersk train. The upper floor of the depot features a control station for monitoring the flow of fuel from the tanks on the roof to the service bay, or from the as-yet-unbuilt tanker truck to the storage tanks. The roof of the facility comes off in two sections. The upper floor features a opening door to the tanks and staircase to the lower floor and the flow-monitoring systems. Emergency fuel shutoff valve and fire extinguisher are at the top level next to the door to the tank area. This is a heavily modified version of set 8486 (Mack's Team Truck) 1950's style semi truck, like the one seen in the 1970's Spielburg movie "Duel". This time, it's a tanker truck in the OCTAN colors scheme. The model can seat one mini figure at the wheel, and features opening doors, a removable roof and a detachable tanker trailer. The tanker section features a moving stand to keep the tank stable when the cab is not there. The trailer is supposed to feature this print on both left, right and rear sides of the tank where the white 1 x 4 tiles are. The idea for this bluebonnet came to me in 2014 when I came upon @raven1280's very similar model, as seen here. I didn't want to use stickers at that time like he did, so I waited, modifying and tweaking the design until the parts came out in the correct colors to warrant it's building. (Particularly the windscreen!) Inside of the cab unit. Inside of the booster unit, with cab unit connected on the left hand side of this locomotive. (Yes, I placed it backwards to what it should be!) (NOTES: Real life model 98% done, just need the tanker truck built.) As usual, Comments, Questions, Suggestions & Complaints are always welcome!
