It's got the same functionality as this one ('cept without Power Functions). There's 189 parts in all (cf. set #8009).
There are two control knobs at the rear (the head spins manually). One deploys the third leg, tilts the chassis forward and keeps the legs level:
The other deploys and operates a grabber arm:
The Rest:
Guts:
Sorry these parts aren't nicely arranged; time has been pretty tight. Hopefully they are all discernible (if not, here's a cobbled together LDD file):
Edited by VMLN8R
Thank you! 'Twas a pain to fill in the back area. Those 9L links move as the third leg is deployed, to keep the feet balanced; unfortunately that means the central has only 5 studs of clearance.
Thanks to you all :)
Zblj; considered some options like that, but didn't want to System it up too much, to keep in consistent with most similarly-sized sets.
