it seems a bit early, but we know how it looks and know its dimensions, so we can go to improve it:
first planetary drive for more power
now how it works
That can be done only electricaly, if you added more gearing you'd loose steering angle.
I meant through gearing. It would lose some steering angle, but we were already discussing that 30 degrees for this kind of vehicle is enough,
is someone sure about the width of the 42030? my second counting is 21, how much studs wide is it when you are counting?
my first counting was the same width of my own loader 23 studs but it seems a bit to wide in relation to the tires
100_0885 von efferman auf Flickr
Edited by efferman
my interpretation of the front carriage. PF-L for bucket lift and bucket tilt and planetary gears for drive. unfortunately the 6x6 dishes are not available in yellow
it should be one stud less in width in relation to 42030
edit:
not sure about the atachment points of the bucket but this is the my version of the bucket arm
Edited by efferman
Hé Efferman,
Would like to see instructons for modification with the mini L.A's when you have done it on the Original model.
I'm gtting this set as soon as my sitiuation lets me.
I am in love with this set already, because I love heavy construction equipement.
please remind me in august when the set is available
btw, its ready for digging
100_0901 von efferman auf Flickr
the actuators for steering
the batterybox sits one stud more in front and now the the rear bumper is closed
rubber connector to secure the mudguards
complete open for maintenance
the underside
maybe the seat is to big or the cab is to small
family photo
which one has the more chunky backside?
Edited by efferman
Hello Efferman,
I Will do that, because if I buy this set, it will have to steer nicely as well.
The hubs with the planetary gearing, I don't think I will use that, but the rest seems very nice.
Christian
Ps: And where did you get the tyres on the wheelloader on the right, seem to be more in place than the ones on the 42030?
Edited by Dafgek81
Only one problem. The white clutch gear slips only in one direction. So i have to the one side a cracking noise of the internal la clutch when they are at the end, and to the other side not.
