Hi guys,
sorry to bother you but I have a problem with PF medium motors for my trains. I've used motors for my 8404 conversion and a small shunter (both with some gear down). Both ran perfectly for some time, but now when I switch them on I only hear a high "beepy" noise but nothing moves. I tried new batteries, got the motors out - nothing helps... Anyone experienced something similar? Do you think the motors are broken.
Appreciate any help, thank you very much.
Seba
My 4.5v motors whine on low power...
Does the motor run without load - out of loco
Can you connect battery to motor without ir
Do have other motors to test with battery and ir
Try and narrow down to which part isn't working :-)
Can you turn the motor by hand when you stick an axle in?
We killed an M-motor last year at a show. On Saturday it had worked fine until it was switched off but on Sunday it was dead...
Thanks guys for your advice.
I can turn the motor by hand - but it does not run outside the motor, or if I just connect it to the battery box. The other PF-components work fine.
Seems like the motor is dead.
Ah well, let s get a new one... :classic:
