I'm in the process if building a AWD car with twin PF L motors. Is it proper to have a differential on the transmission line between the front and rear differentials?
I'm still working on the proportions but as it stands right now 27 studs wide and 56 studs long.
As for type of car it could be a muscle car at this point. Working on the chassis first.
If the car will be driven only on solid, flat surface, then its ok. But if you want it to be able to go over a small bump or to drive over carpet, central diff oculd be a problem (it will stuck a car if only one wheel is off the ground)
You could use the diff to balance the power from the two L motors to the central axle - then it would not be a centre diff but you would ahave a diff in the centre....
Edited by Rockbrick
Here is a picture of the latest revision of the chassis. This is my first time adding a picture. It's a little difficult to reduce the size of the pic on a tablet
