nicjasno has designed a complete new front axle for the unimog 8110 which performs very well: has much better steering and eliminates the very annoying bump steer of the original front axle of the 8110... highly recommended.
But now i have a question about the used building technic - Please have a look at the following picture:
Its a clever build and he uses a round bar 4L to connect thin liftarms by its cross axle holes. Would you judge this a legal building technic to connect liftarms by its cross-holes in other angles than 0 or 90 degree?
It is a pretty common technique in MOCs, although I have never seen it used in an official set. The diameter of the light saber blade is not a coincidence; it was made to fit inside pins and Technic hollow studs. It does not stress any parts. Seems perfectly legal to me.
I am not sure it i'd judge it legal or not. If you put a gun to my head i'd say no; because I don't think it was meant to be used like that. However, I do sympathize with his dilemma. Unfortunately, not all LEGO parts we need actually exist.
Edited by Kelkschiz
Since when have people in MOCs ever stopped using a Lego part because it was not its "intended" use? I find it far more interesting if people come up with a new purpose for a Lego piece. An example: I have seen people use the leg part of a minifig to make up a part of the wall on a modular. Intended use? Nope. Creative and lovely to look at? Yup.
I say it is perfectly fine. I used that part configuration in my halftrack and some older mocs. Worked perfectly.
:thumbup:
I'de say that as long as it's static it's legal. I'de also say that I prefer the original axle because it's more life like, but that's just me :classic: . If only the hubs were deeper and the portal gearboxes designed to fit deeper inside the wheel.
That was not quite what i meant to say. I didn't express myself clearly enough. I think using legs as part of a wall is intended use. I think unintended use is using a piece, that is made a certain way and for a certain purpose, for a different purpose that it was not designed for, like the stresses that will apply to it. This most certainly does not include creative use of parts. If the part in question is a moving part it might damage the LEGO, and that would make it 'unintended use' in my eyes. But as i tried to say, i am not sure either way.
Edited by Kelkschiz
This is a technique that a Technic desginer at Lego would probably only use as a last resort... It is probably only legal in their eyes in certain situations...
They may use it in a place where there is no weight or heavy stress on that part because it isn't as strong as an axle... If I remember correctly that bar has a tendency to slide around as it doesn't have much friction to it(That is a Light Saber rod right?) which is a good thing and a bad thing as it could possibly work itself loose from repeated movement...
Putting the bar inside a cross axle hole is legal, but I do believe that I see a illegal technique being used here, can you spot it.
It's the 2 x 2 L shaped plate that is inserted studs first into the liftarm below it... It's right below the arrow...
Yes that's an illegal technique for sure!
No studs allowed into Technic holes.
I've done this a couple times in a few of my models(My Porsche) with trans clear plates inserted into technic connectors and once I was told that was not allowed, I have serched for other methods... :wink:
Theory is that it stress the studs and decrease their clutch power.
Techniques that are supposed to damage parts are never allowed.
Of course unless there is no choice to break the rules.. Like they did with a certain blue pin in the 8043 excavator... And since then I have used it the same way on several occasions...
If it works for Lego right..?
