Effe, I love the turntable idea. How much would it cost to get printed? I would definitely be interested if it was cheap enough.
EDIT: What would a studded version look like? Would that work too?
tim
Edited by timslegos
tim
Probably more that you get in pocket money for being a a good boy... :laugh:
There is a much easier alternative, but works for a single wire/tube ... or maybe few, but they must be bundled together.
Here is a little puzzle in topology ... how do you transmit electrical/pneumatic power from a part that is fixed, to one that is rotating, WITHOUT any twisting?
This can be done rather 'easily', without any complex seals/rings/ ...
What I would like is if you could only make the top and bottom with a thread fitting so we could use brass tubing to screw onto each end to make the size we need.
The internal part should be the same way.
you forgot the piston rod. if you change the length of the cylinder you need a new piston rod. the solution in my post up yours uses two piston rods of standard cylinders.
I said that the should be made the same way with to threaded end parts.
Edited by Alasdair Ryan
The 3d print shuold be no problem, only the inner side of the upper part must get a smooth surface before assembling. The gaskets are simple 6x1 O-rings (6mm inner diameter). Tomorrow i will assemble it together with a turntable to show how it will look installed.
