legovintage Posted June 6, 2013 Posted June 6, 2013 (edited) Hi, I've the same problem shown in this video: Someone could explain me why it happens and if is possible solve it? Thanks!!! Edited June 6, 2013 by legovintage Quote
LegoGBC Posted June 6, 2013 Posted June 6, 2013 Read here: http://www.technicbricks.com/2012/11/lego-power-functions-incompatibilities.html Quote
legovintage Posted June 6, 2013 Author Posted June 6, 2013 (edited) thank you! it seems that the only solution is using two IR receivers, one for each motor, with same channel...or "just" wait the new motor :\ Lego really disappointed me this time... =.= Edited June 6, 2013 by legovintage Quote
Phoxtane Posted June 6, 2013 Posted June 6, 2013 If you're looking to combine two M-motors together into one drivetrain, try using a differential between them. Quote
Zerobricks Posted June 6, 2013 Posted June 6, 2013 On 6/6/2013 at 1:11 PM, Phoxtane said: If you're looking to combine two M-motors together into one drivetrain, try using a differential between them. That wont help here. This is an electricl issue, not mechanical... Just use the V1 receiver! Quote
Phoxtane Posted June 6, 2013 Posted June 6, 2013 Ah, that was going to be my second guess - isn't this the problem where the V2 receiver trips the M-motor's internal circuitry? Either way, Zblj is right. A V1 receiver ought to do nicely. Quote
legovintage Posted June 6, 2013 Author Posted June 6, 2013 I don't have it :P but good to know^^ Quote
dhc6twinotter Posted June 7, 2013 Posted June 7, 2013 (edited) So, I'm confused. Why would the V2 receiver work with 2 L motors, but not 2 m motors? I thought the V2 receiver was supposed to be better when used with 2 motors? EDIT: Nevermind....I should have read the link posted earlier first. I didn't know there were issues with the V2 receiver and the m motors. Pretty interesting and good to know. Edited June 7, 2013 by dhc6twinotter Quote
