ddimkin Posted July 25, 2014 Posted July 25, 2014 Hi All, I am new to LDD - intending to build my own rock crawler. I installed the software today and also downloaded LDD Partfinder. I have L-motors and I am not really sure if they are present in LDD. I am using extended mode. When I search for "motor" I find a small motor, func. motor 24x6M and func.motor 40x6M. Not sure how to read this?? Thanks a lot!!!! Quote
Calabar Posted July 25, 2014 Author Posted July 25, 2014 Try to search using the Design ID: the one for the L-Motor is 88003. Quote
Zerobricks Posted July 26, 2014 Posted July 26, 2014 L and Servo motors are still missing in LDD... Quote
Takanuinuva Posted October 7, 2014 Posted October 7, 2014 Is this piece used in mars mission in Ldd? http://www.bricklink.com/catalogItemIn.asp?P=61680&colorID=86&in=A Quote
Zerobricks Posted October 7, 2014 Posted October 7, 2014 Searching 61680 in LDD extended mode shown no results... Quote
inrfb Posted October 10, 2014 Posted October 10, 2014 Hello *. *, slightly desperate I am looking for a model of a left and right switch for the Lego Cad program LDD 4.3 (or LDraw). Specifically I am looking for models for the switches set 7895 Is there something somewhere ??? THANKS for the info! MfG Bernd PS The other tracks I've found ..... Quote
Superkalle Posted October 10, 2014 Posted October 10, 2014 I'm moving this to the right topic. The answer to your question is that they exist under the Electrical Icon in LDD (the electric motor icon). Quote
Courleciel Posted October 10, 2014 Posted October 10, 2014 Hi, Is the part n°3651 available on LDD ? Quote
mzoli Posted October 10, 2014 Posted October 10, 2014 Hi Courleciel, That part is not in LDD, I use 32126 as a replacement. Quote
Courleciel Posted October 10, 2014 Posted October 10, 2014 Thanks for your answer. That's what I feared. I hope this part will be added for the next update. Quote
mzoli Posted October 10, 2014 Posted October 10, 2014 We cannot expect it, since this part was discontinued in 2003. The legacy Technic parts would be welcome but this is wishful thinking only... Quote
DrJB Posted December 9, 2014 Posted December 9, 2014 I'm looking for this specific part/assembly but can't find it in LDD. What makes it complicated is that the bricklink designation ( x873c01) does not resemble any I've seen for other lego parts. Any one with a clue? Quote
Zerobricks Posted December 9, 2014 Posted December 9, 2014 That part is sadly not in LDD and its also outdated by newer hubs. Quote
DrJB Posted December 9, 2014 Posted December 9, 2014 I was afraid this was going to be the case ... thank you for 'confirming' my fears :) Quote
Zerobricks Posted December 9, 2014 Posted December 9, 2014 I was afraid this was going to be the case ... thank you for 'confirming' my fears :) That sounds so sad and cruel I did saw a replacement assembly somewhere... I think... Quote
DrJB Posted December 9, 2014 Posted December 9, 2014 That sounds so sad and cruel I did saw a replacement assembly somewhere... I think... Yes, I'm doing an LDD of Crowkillers Murcielago ... and need a way to attach the wheels ... lol ... maybe I can convert it to a hover-craft. Quote
P3_Super_Bee Posted June 6, 2015 Posted June 6, 2015 Maybe it's not there, but that would be odd if it is not. I'm looking for x100c01 minifig: weapon cannon shooting Why I would find it odd that it wouldn't be there is the mount: 2527 minifig, cannon weapon base 2x4 is there. Bricklink also list these part numbers as similar, can't find them either. 2533c01 518 bb39 Any help would be appreciated Quote
Classicsmiley Posted June 6, 2015 Posted June 6, 2015 Did you search for "cannon" in LDD? The part is there under part 84943. Quote
P3_Super_Bee Posted June 6, 2015 Posted June 6, 2015 Did you search for "cannon" in LDD? The part is there under part 84943. LIke type in "cannon" in the search bar? Doesn't work. Nothing shows up for "Cannon" nor 84943... Ahh. It's in the expanded side. I was in the standard side. Thanks. Quote
Classicsmiley Posted June 7, 2015 Posted June 7, 2015 I never use the standard palette, so most of the time I forget it's even there. If you're ever looking for a part, always start with the Extended palette. Quote
StormNL Posted June 23, 2015 Posted June 23, 2015 How do you get the cockpit and fuselage in, I use LDD but I can't find it anywhere. Quote
Classicsmiley Posted June 23, 2015 Posted June 23, 2015 Welcome to Eurobricks! Which cockpit and fuselage are you talking about? Can you list a set number where you've seen the pieces you are interested in? Also, one thing you should probably do when using LDD is to make sure you are using the Extended palette of bricks. Quote
ilikeboomerang1 Posted August 3, 2015 Posted August 3, 2015 (edited) Hi guys, I'm new here. I wonder where the Train Wheel RC, Holder is. I tried using the part number (2878) but I still don't see it. Thanks for helping! EDIT: I found the complete assembly of it in LDD Extended, but since I built what I needed it for in LDD normal, now what I need help is moving that to LDD Extended. Edited August 3, 2015 by ilikeboomerang1 Quote
