But you so know as far as i noticed the PF switches also limit current to motors a bit. Try one motor directly to Bb and one via switch. There is a bit of difference.
really? ok, then i should switch the battery boxes directly. the cab should big enough for this and maybe i build this and then it should have really enough space and weight
picture source
edit:
the final baseframe is finished
100_0487 von efferman auf Flickr
Edited by efferman
Frame is so solid. Be careful- dont injure or damage something around you with this huge construction:))
Edited by rm8
The perfect crime − after the murder, he could just disassemble the "blunt instrument" and build something else with the parts :)
Hey, your Tatra-model looks cool, good work :classic:
Btw, new member here, been a big fan of Lego Technic for many years, had to sign up here when I found this forum :laugh:
when you think i have build a tatra, then i have made not a good work :wink:
I am afraid that it became heavy to the end of building, dont you?
if it would be a flatbed, you would be right, but the crane will be tricky. so i think i have roundabout 60 percent
picture source
Edited by efferman
How come? Didn't you aim to build a model similar to the Tatra truck?
@Error404: have a close look at the picture in post #902 and read slowly at the front of the cab... Or look at the picture in post #910. What is on the door?
I don't see a t or a r
