Hello everyone, I'm new to this forum because I need some help.
I wanted to build a prmission of 2:15 using gears.
I could not find a way to make it, so can you help me? It should be quite efficient, of course. If you know a way how to build it, could you please describe it for me?
Thank you.
Lego has gears with 8, 12, 16, 20, 24, 36 and 40 teeth. Dividing out the common factor 4, this is 1, 2, 3, 4, 5, 6, 9, 10. The prime factors available are 2, 3 and 5. As both 2 and 15 consists only of those prime factors, this is doable with simple gear reductions only.
2:15 is 2 : (3 x 5)
so it can be either 2:3 times 1:5 or 1:3 times 2:5.
2:3 is 8 to 12 or 16 to 24, the last one is most practical.
1:3 is 8 to 24
1:5 is 8 to 40
2:5 is 8 to 20 or 16 to 40, the last one is most practical.
As the distance between the centers of two gears is 1/16 times the sum of their teeth, the distances between the holes in these four setups is a multiple of 1/2 stud each, so these can easily be secured with bricks with holes in a horizontal setup.
Edit: what I mean with the last remark is this:
Edited by Erik Leppen
"Sariel" (Paul Kmiec) posted his "Gear Ratio Calculator 2" on his excellent website. Read about it at http://sariel.pl/2010/04/gear-ratio-calculator-2-released/ ; the actual calculator is at http://sariel.pl/tools/ratios/ . One can place any type of "Driver Gear" and "Follower Gear" on a 6x6 hole grid, and there's a pictorial output and some data like:
"The gear ratio is 1.8:1"
"The speed is increased 1.8 times.
The torque is decreased 1.8 times.
The follower gear rotates 1.8 time per each revolution of the driver gear."
Cool! :wink:
Edited by DLuders
2:15 equals 1:7.5. You can achieve that easily using two pairs of gears: one with 1:3 ratio and another with 1:2.5 ratio (as 3 x 2.5 = 7.5). As Eric pointed our, the simplest possible combination is 8t gear > 24t gear in the first pair and 16t gear > 40t gear in the second pair.
Edited by Sariel
Use 12:20 to 8:24 to get 5 and another 8:24 to get 15. Than use 12:24 to get 2 and connect them both via a diff.
Is this Lego Antikythera mechanism approach?
I don't think that works -- or maybe I'm misunderstanding what you're suggesting. If you connect 1/15 and 1/2 by a diff you get (1/15 + 1/2)/2 = 17/60. Conversely, if you connect 15 and 2 by a diff you get (15 + 2)/2 = 8.5
Sort of - using differentials lets you add, whereas regular gearing up and down only lets you multiply -- the output of a diff with inputs A and B is (A + B)/2. You can also subtract by negating (reversing direction) of one of the inputs, or by treating the differential casing as one of the inputs. This means with a bit of thought you can get any gear ratio you want, including ones that don't have 2,3,5 as prime factors.
Yeah the other sone should be 24 to 12 :classic:
