Hi everyone,
I want to share MOCPilot — an app for controlling LEGO®-powered creations (MOCs, official sets, robots/mechanisms) from a phone/tablet, and it’s also available on Apple devices including macOS.
You can build custom control “profiles” and automate behaviors using a Scratch-like block system.
Official site / Documentation
What MOCPilot does
1) Profiles (control layouts)
  • Create a custom “profile” per model (your own MOC or a set)
  • Add on-screen controllers (steering, sliders, buttons, etc.) and connect them to motors/ports
  • Monitor hub status + sensor values in real time
2) Gamepad support (full controller driving)
  • You can connect a physical gamepad to your phone/tablet/Mac and drive your model with sticks/triggers/buttons
  • MOCPilot provides dedicated gamepad blocks you can use inside a profile program, so gamepad inputs can directly control motors or trigger custom logic (e.g. gears, lights, sequences, modes)
3) Visual programming (Scratch-like blocks)
  • Drag-and-drop blocks to build anything from simple drive code to automation sequences
  • Use events/logic to react to sensors and hub state
  • Works offline for designing/testing your programs
4) Multi-hub builds
  • A single profile can control multiple hubs at once
  • By default you can add up to 2 hubs per profile; can be extended up to 5 hubs via extra hub slots
user-hub-selection-9d88b0c7a53e6659c9ace
connect-hub-flow-ba419ba25bd43e30c5f2a9b
hubs-connected-910f4e8fe6d1c1b4a93c3acea
Supported hubs
  • LEGO® WeDo 2.0 Smart Hub (45301-1)
  • LEGO® Technic™ Hub (880012)
  • LEGO® Technic™ Move Hub (103479c01)
  • LEGO® Move Hub (88006)
  • LEGO® Hub (88009)
  • LEGO® Remote Control (88010)
  • LEGO® Large Hub (88016) (not available on iOS)
  • BuWizz® 2.0 Hub
  • BuWizz® 3.0 Pro Hub
  • Mould King 4.0 (M0006)
  • Mould King 6.0 (M0019)
Supported motors
  • Technic™ Large Motor (88013)
  • Technic™ XL Motor (88014)
  • Large Angular Motor (88017)
  • Education Large Angular Motor (45602)
  • Medium Linear Motor (88008)
  • Simple Medium Linear Motor (45303)
  • Train Motor (88011)
  • Medium Angular Motor (88018)
  • Medium Angular Motor (45603)
  • Small Angular Motor (45607)
  • Light (88005)
Supported sensors
  • Color & Distance Sensor (88007)
  • Distance Sensor (45604)
  • Color Sensor (45605)
  • WeDo 2.0 Tilt Sensor (45305-1)
  • WeDo 2.0 Motion Sensor (45304-1)
Prebuilt profiles (official sets / ready-to-run)
MOCPilot includes Prebuilt profiles so you can quickly control supported official sets and also learn from ready-made block programs.
Important detail: you can experiment and edit a prebuilt profile, but changes aren’t saved — it resets to the original version next time you open it.
Typical use cases
  • Drive & steer Technic vehicles with a clean dashboard UI (on iPhone/iPad/Android tablet, or on a Mac)
  • Use a gamepad for realistic driving feel, plus custom actions mapped to buttons
  • Create realistic sequences (startup, shifting, lights) using blocks
  • Program sensor-based behaviors (distance/color/tilt triggers)
  • Control complex creations by splitting functions across multiple hubs (drive + gearbox + crane + lighting)
Edited by _Ozzee_
The formatting has been updated, and additional screenshots have been added.
